Printer Specifications for HP Sprocket Photo Printers
This document is for HP Sprocket Photo Printers.
Review this document for detailed technical data, such as product numbers, system requirements, print speeds, connectivity types, physical dimensions, power supply, paper handling, and printing specifications.
Figure : HP Sprocket Photo Printers
Printer specifications
Specification
Product numbers
X7N07A (White)
X7N08A (Black)
Z3Z89A (White)
Z3Z90A (Black)
Z3Z91A (White)
Z3Z92A (Black)
Z3Z93A (Red)
Z3Z94A (Gold)
Z9L25A (Metablue)
Z9L26A (Purple)
Dimensions and weight
116 x 75 x 23 mm (4.53 x 2.95 x 0.87 in)
0.172 kg (0.379 lb)
Connectivity
Bluetooth 3.0
Passive near field communication (NFC)
Printer management
HP Sprocket app
Power supply
Up to 35 prints per charge
Internal rechargeable battery
Two-cell 500 mAh Li-Polymer 7.4 V
Charge time
Up to 90 minutes
Power consumption
0.9 W (standby)
Average 15.91 W (based on first print)
Maximum 34.49 W at 25° C (77° F)
Print technology
Thermal printing with a ZINK® Zero Ink® printer
The printer does not use ink cartridges to print.
Supported paper
HP sprocket photo paper
5.0 x 7.6 cm (2 x 3 in)
Borderless printing
Yes
Support file types
BMP
GIF
JPEG
PNG
TIFF (iOS only)
If you send a non-supported file type, the print job does not print.
Paper tray capacity
Up to 10 pages with the HP Smartsheet®
Memory
Up to 512 MB
Print quality
313 x 400 dots per inch (dpi)
Print speed
Up to 40 seconds
Mobile operating systems and devices
Supported by Android mobile devices with OS v4.4 and later
Compatible with Apple iPhone 7 Plus, Apple iPhone 7, Apple iPhone SE, Apple iPhone 6s Plus, Apple iPhone 6s, Apple iPhone 6 Plus, Apple iPhone 6, Apple iPhone 5s, Apple iPhone 5c, Apple iPhone 5, Apple iPod touch (6th generation), Apple iPad Pro (9.7 inch), Apple iPad Pro (12.9 inch), Apple iPad Air 2, Apple iPad Air, Apple iPad (5th generation), Apple iPad (4th generation), Apple iPad mini 2, Apple iPad mini 3, Apple iPad mini 4
Control panel
Power button
Reset button
Charge and status light indicators
Environmental parameters
Operating humidity: 5% to 70% RH (recommended)
Non-operating humidity: 5% to 90% RH
Operating temperature: 5° to 40° C (41° to 104° F)
Recommended operating temperature: 15° to 32° C (59° to 90° F)
Storage temperature: -30° to 70° C (-22° to 158° F)
One-year limited hardware warranty
Visit the HP Sprocket homepage for more information.
Regulatory model number
For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is SNPRH-1603. This regulatory number should not be confused with the marketing name (HP Sprocket Photo Printer) or the individual product numbers.
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
This product generates no appreciable ozone gas (O3).
HP offers an increasing number of product return and recycling programs in many countries and regions, and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. For more information about the recycling of HP products, go to www.hp.com/hpinfo/globalcitizenship/environment/recycle/ (in English).
