HP Spectre 13-v029tu Product Specifications
X4G16PA
Intel® Core™ i7-6500U (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
8 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
Intel® HD Graphics 520
256 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD UWVA BrightView WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
WiDi; Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 headphone/microphone combo; 1 USB 3.1 Gen 1 (Type-C™, HP USB Boost); 2 USB 3.1 Gen 2 (Type-C™, HP USB Boost, Thunderbolt)
32.5 x 22.9 x 1.04 cm
Starting at 1.16 kg
45 W USB Type-C™ adapter
4-cell, 38 Wh Li-ion
HP TrueVision HD Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Quad speakers
Windows 10 Pro 64
HP Support Assistant; HP Recovery Manager; HP Documentation; HP ePrint
Pre-installed software
Adobe® Shockwave® Player
