    Apache Log4j Update
HP ENVY Notebook 15-as012tu Product Specifications
X0H31PA
Intel® Core™ i5-6200U (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
Intel® HD Graphics 520
1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal FHD IPS UWVA BrightView WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 3 USB 3.0 (1 HP USB Boost); 1 USB 3.0 (Type-C™)
38 x 25.5 x 1.79 cm
3-cell, 52 Wh Li-ion
Bang & Olufsen; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Documentation
Pre-installed software
Adobe® Shockwave® Player; CyberLink PowerDirector; Dropbox; TripAdvisor
