HP Chromebook 11 G5 - Specifications
Feature
Preinstalled
Chrome OS
Processor
Processor
Intel Celeron N3060 (1.60 GHZ, Turbo up to 2.48 GHz) 2 MB 1600 MHz L2 cache, 2 cores
Integrated SoC PCH
Graphics
Feature
Intel HD Graphics 400
Supports HD Decode, DX12, and HDMI
Feature
Internal
Touch
11.6 in diagonal HD WLED slim eDP UWVA, (1366 x 768) with Corning Gorilla Glass NBT
Non-touch
11.6 in diagonal HD WLED flat eDP SVA Anti-glare (1366 x 768)
External
HDMI v1.4b
Supporting up to 1920 x 1080 at 60 Hz
Storage and drives
Feature
Support eMMC
16 GB
32 GB
Store up to 100 GB with Google Drive (2-year subscription included)
This offer is tied to this device and is non-transferable. If this device is returned, the extra storage will be revoked. In order to redeem this offer, you will need to be on Chrome OSTM 23 or later. Internet access is required and not included.
Memory
Feature
Standard
Memory soldered down
LPDDR3-1600 Single Channel (Transfer rates up to 1600 MT/s) for 2 GB Memory
LPDDR3-1600 Dual Channel (Transfer rates up to 1600 MT/s) for 4 GB Memory
Support
4 GB maximum
Networking/communication
Feature
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 7265 802.11a/b/g/n/ac (2x2) WiFi and Bluetooth 4.2 Combo
Internal card expansion
One M.2 slot for WLAN
Audio/multimedia
Feature
Audio
HD Audio
Dual speakers
HP TrueVision HD
HD camera - Indicator LED, USB 2.0, f2.0
720p by 30 frames per second
Dual array digital microphone with appropriate software - beam forming, echo cancellation, noise suppression
Keyboards/pointing devices
Keyboard
Full size textured island-style keyboard
Ash gray
Clickpad
Clickpad with image sensor
Multitouch gestures enabled
Taps enabled as default
Software and security
Preinstalled software
Chrome OS and its default set of apps
Security
Trusted Platform Module (TPM) 1.2
Lock slot
Optional UltraSlim Kensington security lock (sold separately)
Power
Specification
Power supply
HP 45 W Smart AC adapter
HP 65 W EM Smart AC adapter (India only)
Power cord included is 1 m (3.3 ft)
Primary battery
2-cell (43.7 WHr) Polymer battery
Weight and dimensions
Specification
Non touch
Starting at 1.14 kg (2.51 lb)
Touch
Starting at 1.87 kg (2.61 lb)
Dimensions (W x D x H)
20.5 x 28.6 x 1.84 cm (8.07 x 11.25 x 0.72 in)
Ports/slots
Specification
Ports
(2) USB 3.1 Gen 1 (One on the left side and one on the right) - Both USB ports support USB boost
(1) Headphone/microphone combo jack
(1) HDMI v 1.4
HP Multi-Format Digital Media Card Reader
Support SD/SDHC/SDXC up to UHS-104 (left side)
Push-push insertion/removal
