    Fix HP Printer issue on macOS
HP PageWide Enterprise Color MFP 586 - Removal and replacement: Document feeder white backing (586)
This guide shows the HP LaserJet Enterprise MFP M527. However, the instructions are also valid for the HP PageWide Enterprise Color MFP 586.
This document provides the procedures to remove and replace the document feeder white backing (586).
Before performing service
Turn the printer power off
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
White backing kit part number
G1W41-67903
White backing with instruction guide1
1This kit includes the retention clip kit and instruction guide.
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
No post service test are available for this assembly.
Step 1: Remove the white backing
  1. Open the document feeder.
    Figure : Open the document feeder
  2. Pull down on the white backing to remove it.
    Figure : Remove the white backing
  3. If any of the retention clips (callout 1) remain attached to the white backing (or are damaged), go to step Verify that the spring is positioned correctly on the retention clip (replacement clips are supplied with this kit)..
    If none of the retention clips remain attached to the white backing (or are not damaged), go to Step 2: Unpack the replacement assembly.
    Figure : Check the white backing
  4. Verify that the spring is positioned correctly on the retention clip (replacement clips are supplied with this kit).
    Figure : Check the clip spring
  5. Install the replacement clip (callout 1) in the opening (callout 2) in the document feeder.
    Figure : Install the clip
  6. Press the clip to make sure it is securely installed.
    Figure : Press the clip
  1. Dispose of the defective part.
  2. Unpack the replacement part from the packaging.
    If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands or before touching rollers or pads.
    Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
Step 3: Install the white backing
  1. Place the white backing on the scanner glass.
    Place the corner of the backing that does not have a hook-and-loop fastener in the upper-left corner of the scanner glass.
    Figure : Place the white backing on the glass
  2. Close the document feeder.
    Figure : Close the document feeder
  3. Open the document feeder and make sure that the white backing is securely attached.
  4. Close the document feeder.
