    Fix HP Printer issue on macOS
Document ID: c05163646
Version: 1
HP Elite X2 1012 Tablet PCs - POST Error Displays Real-Time Clock Power Loss (005)
Release date : 06-Jun-2016
Last updated : 06-Jun-2016
DESCRIPTION
The Real-Time Clock (RTC) Power loss (005) error is displayed when the main battery has been drained. Depending on the BIOS version, the battery drains in several days and or weeks in which the RTC battery also appears to drain. This occurs when the tablet has been off and has been stored for a long period of time.
When reconnecting power to the tablet, the following error is displayed:
The system time is invalid. This may be a result of a loss of power.
Set the correct time and date using your operating system. If this message persists, You may need to replace the onboard battery.
Factory Defaults Settings Loaded
Real-Time Clock Power loss (005)
Enter-Reboot the System
For more information, please visit www.hp.com\go\techcenter\startup
Symptoms:
Choosing to press ENTER to restart the tablet is difficult without the keyboard attached.
SCOPE
The information in this document applies to the following:
Tablets:
  • HP Elite x2 1012 Tablet
RESOLUTION
To resolve this issue, plug in power adapter to let the battery fully recharge, then enter Windows and reset the date and time.
To help prevent this issue from reoccurring, download and install the following SoftPaq update the BIOS to 1.15.
SoftPaq Description
Release Notes
Download SoftPaq
HP Notebook System BIOS Update
Version: 01.15
Revision: A
NOTE: If the computer is left idle for long periods the battery can drain completely. The Battery will drain over time even when the computer is off.
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/drivers.
Hardware platforms affected : HP Elite x2 1012 G1
Support Communication Cross Reference ID : IA05163646
