The HP 20kd is a 49.5 cm (19.5 in) Monitor.
Figure : HP 20kd Monitor
LED feature
Specification
Display size
49.5 cm (19.5 in) diagonal
Display type
IPS with Anti-glare
Panel active area
41.9 x 26.2 cm (16.5 x 10.3 in)
Brightness
250 nits
Color gamut
72%
Inputs
1 VGA
1 DVI-D
note: |
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1440 x 900 @ 60 Hz
Aspect ratio
16:10
Static contrast ratio
Up to 100:1
Dynamic contrast ratio
Up to 6,000,000:1
Response time
8 ms on/off (typical)
Power consumption
20 Watts max
Tilt
-5 to +15 degrees
Dimensions
W x D x H (unpacked):
45.5 x 19.4 x 37.6 cm (17.9 x 7.7 x 14.8 in)
Unpacked: 2.9 Kg (6.3 lbs)
