    Apache Log4j Update
HP Spectre 13-v021nr (ENERGY STAR) Product Specifications
W2K28UA
Intel® Core™ i7-6500U with Intel® HD Graphics 520 (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
8 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
  • Intel® HD Graphics 520 (up to 4.09 GB)
  • Integrated
256 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS UWVA BrightView Corning® Gorilla® Glass WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit
Pointing device
802.11ac (2x2) and Bluetooth® 4.0 combo
2 USB 3.1 Gen 2 (Type-C™, HP USB Boost, Thunderbolt); 1 USB 3.1 Gen 1 (Type-C™, HP USB Boost); 1 headphone/microphone combo
32.5 x 22.9 x 1.04 cm
1.1 kg
45 W AC power adapter
4-cell, 38 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen; Quad speakers
HP ePrint; HP Support Assistant
McAfee LiveSafe™ 30-day trial offer (Internet access required. First 30 days included. Subscription required for live updates afterwards.)
Pre-installed software
Netflix
