HP LD5511 55-inch Large Format Display - Specifications
Panel
Specification
Model
T5X84AA
Type
138.78 cm (54.64 in) diagonal D-LED backlight panel
138.78 cm (54.64 in) widescreen; diagonally measured
Panel active area (W x H)
120.96 x 68.04 cm (47.62 x 26.79 in)
Aspect ratio
16:9
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness
350 nits (cd/m2)
Contrast ratio (typical)
1200:1
Response times
9 ms gray to gray
Pixel pitch
0.63 mm
Color gamut (typical)
68%
On Screen Display (OSD) Controls
Specification
Buttons or switches
Menu
Volume ("-"/"+")
Up
Down
Input
Mute
Power
Languages
Chinese (Simplified), English, French, German, Italian, Polish, Russian, Spanish, Turkish
User controls
Brightness, Contrast, Color, Image Control, OSD Control, Language, Information, Factory Reset, Input Control, Audio Control
Signal interface/performance
Specification
Horizontal frequency
31.5 to 91.1 kHz
Vertical frequency
50 to 85 Hz
Native resolution
1920 x 1080 at 60 Hz
Max resolution
1920 x 1200 at 60 Hz
Preset VESA Graphic modes (non-interlaced)
640 × 480 at 72Hz DMT
640 × 480 at 75Hz DMT
800 × 600 at 56Hz DMT
800 × 600 at 60Hz DMT
800 × 600 at 72Hz DMT
800 × 600 at 75Hz DMT
832 × 624 at 75Hz MAC
848 × 480 at 60Hz DMT
848 × 480 at 75Hz CVT
1024 × 768 at 60Hz DMT
1024 × 768 at 70Hz DMT
1024 × 768 at 75Hz DMT
1024 × 768 at 76Hz IBM
1152 × 864 at 60Hz
1152 × 864 at 70Hz
1152 × 864 at 75Hz DMT
1152 × 870 at 75Hz MAC
1152 × 900 at 66Hz SUN
1152 × 900 at 76Hz SUN
1280 × 720 at 60Hz CVT16:9
1280 × 720 at 75Hz CVT16:9
1280 × 768 at 60Hz CVT16:10
1280 × 768 at 75Hz CVT16:10
1280 x 800 at 60Hz CVT16:10
1280 x 800 at 75Hz CVT16:10
1280 × 1024 at 60Hz DMT
1280 × 1024 at 66Hz SUN
1280 × 1024 at 75Hz DMT
1280 × 1024 at 76Hz SUN
1360 × 768 at 60Hz DMT
1440 × 900 at 60Hz CVT16:10 R
1440 × 900 at 75Hz CVT16:10
1600 × 900 at 60Hz RE16:9
1600 × 1200 at 60Hz CVT16:9
1680 × 1050 at 60Hz CVT16:9 R
1920 × 1080 for XBOX360
1920 × 1080 at 60Hz CVT16:9 R
Maximum pixel clock speed
165 MHz
User programmable modes
Yes, 26
Anti-glare
Yes
Default color temperature
9300K
Video/other inputs
Specification
RS232C
1 input and 1 output
Input Signal
VGA (D-Sub)), DVI-D, HDMI, YPbPr HDCP support on DVI and HDMI
Plug and play
Yes
IR
Input/output; for receiving and sending the IR control signals
USB
USB 2.0 input for firmware update and playing multimedia files.
Cables included
(1) VGA 1.8 m (5.9 ft)
(1) HDMI 1.8 m (5.9 ft)
Audio
N/A
Power
Specification
Input power
100 - 240 VAC
Frequency
50/60 Hz
Internal
Typical power consumption
141 W
Maximum
179 W
Power saving
Sleep: 0.5 W
Power cable length
1.8 m (5.9 ft )
Mechanical
Specification
Dimensions (W x D x H)
Unpacked with stand: 123.86 x 75.17 x 32.96 cm (48.76 x 29.59 x 12.98 in)
Unpacked without stand (head only): 123.86 x 71.11 x 6.17 cm (Wall Mount)/59.9 cm (Rear Cover) 48.76 x 28 x 2.43 in (Wall Mount)/2.36 in (Rear Cover)
Packaged: 137.5 x 87.4 x 19.6 cm (54.13 x 34.41 x 7.72 in)
Bezel
Bezel width on top/right/left sides = 12.6 mm (0.5 in)
Bezel width on bottom = 14.5 mm (0.57 in)
Environmental
Specification
Temperature
Operating: 5° to 40° C (41° to 104° F)
Non-operating: -20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 10% to 90%, 38.7° C max wet-bulb
Altitude
Operating: 0 to 3,000 m (0 to 9,842 ft)
Non-operating: 0 to 9,000 m (0 to 29,528 ft)
