HP Z1 G3 Workstation - Specifications
Feature
Preinstalled
Windows 10 Pro 64-bit
Windows 10 Pro 64-bit Downgrade to Windows 7 Professional 64-bit
Linux Ready (T0K20AV)
Red Hat Enterprise Linux Desktop/Workstation
Must still obtain the Red Hat software bits from Red Hat.
Supported
Windows 10 64-bit
Windows 10 Pro 64 Downgrade Win 7 64
Windows 10 Home 64 High-End
Red Hat Enterprise Linux Desktop/Workstation 6, 7
Processors
Intel Xeon E3-1270v5 3.6 8M GT0 4C CPU
Cores: 4
Clock Speed: 3.6 GHz
Intel Turbo Boost Technology: 4.0
Cache: 8 MB
Memory Speed: 2133 MT/s
Hyper-threading: Yes
Featuring Intel vPro Technology: Yes
TDP: 80W
Intel Xeon E3-1245v5 3.5 8M GT2 4C CPU
Cores: 4
Clock Speed: 3.5 GHz
Intel Turbo Boost Technology: 3.9
Cache: 8 MB
Intel HD Graphics: Intel HD Graphics P530
TDP: 80W
Intel Xeon E3-1225v5 3.3 8M GT2 4C CPU
Cores: 4
Clock Speed: 3.3 GHz
Intel Turbo Boost Technology: 3.7
Cache: 8 MB
TDP: 80W
Intel Core i7-6700 3.4 8M 4C CPU
Cores: 4
Clock Speed: 3.4 GHz
Intel Turbo Boost Technology: 4.2
Cache: 8 MB
Intel HD Graphics: Intel HD Graphics 530
TDP: 65W
Intel Core i5-6500 3.2 6M 4C CPU
Cores: 4
Clock Speed: 3.2 GHz
Intel Turbo Boost Technology: 3.6
Cache: 6 MB
TDP: 65W
Intel Core i3-6100 3.7 3M 2C CPU
Cores: 2
Clock Speed: 3.7 GHz
Cache: 3 MB
TDP: 65W
Integrated displays
Feature
Type
IPS (in-plane switching) LED Backlit LCD
Viewable image area
60 cm (23.6 in) widescreen; diagonally measured
Screen opening (W x H)
52.1 x 32.1 cm (20.5 x 11.5 in)
Optimal resolution
3840 x 2160 at 60 Hz; 8.3 MP
Aspect ratio
16:9 Widescreen
Viewing angle (typical)
Up to 178° horizontal / 178° vertical
Maximum brightness (typical)
300 nits cd/m2
Minimum brightness (typical)
50 nits cd/m2
Contrast ratio (typical)
1000:1
Dynamic contrast ratio (typical)
N/A
Response time (typical)
14 ms (gray to gray)
Pixel pitch
0.04525 mm x 0.13575 mm
Backlight LED life time
30,000 hours minimum
Color gamut coverage of sRGB
100% (CIE 1931)
Color support
Up to 16.7 million colors
Monitors/displays
HP DreamColor Z24x Display
HP DreamColor Z27x Studio Display
HP DreamColor Z32x UHD Display
HP Z Display Z24i 24-inch IPS LED Backlit Monitor
HP Z Display Z30i 30-inch IPS LED Backlit Monitor
HP Z22n Narrow Bezel IPS Display
HP Z23n Narrow Bezel IPS Display
HP Z24n Narrow Bezel IPS Display
HP Z24nf Narrow Bezel IPS Display
HP Z24nq Narrow Bezel IPS Display
HP Z24s IPS UHD 4K Display
HP Z25n Narrow Bezel IPS Display
HP Z27n Narrow Bezel IPS Display
HP Z27q 27-inch IPS 5K Display
HP Z27s IPS UHD 4K Display
HP Z34c Curved Display
HP Zvr Virtual Reality Display
Storage and drives
Feature
SATA hard drives
1 TB SATA 7200 rpm 6 Gb/s 2.5 in HDD
500 GB SATA 7200 rpm 6 Gb/s 2.5 in HDD
SATA SSDs
HP 1TB SATA 6 Gb/s SSD
HP 512 GB SATA 6 Gb/s SSD
HP 256 GB SATA 6 Gb/s SSD
HP 256 GB SATA 6 Gb/s SED Opal SSD
PCIe SSDs
HP 1 TB Z-Turbo NVMe M.2 SSD
HP 512 GB Z-Turbo NVMe M.2 SSD
HP 256 GB Z-Turbo NVMe M.2 SSD
Hard drive controllers
RAID 0 Configuration - Striped Array
RAID 1 Configuration - Mirrored Array
Graphics
Feature
Integrated Intel HD Graphics
Entry 3D
NVIDIA Quadro M1000M 2GB Graphics
Mid-range 3D
NVIDIA Quadro M2000M 4GB Graphics
Memory
Feature
DDR4-2133 nECC Unbuffered DIMMs CTO
HP 32 GB (2 x 16 GB) DDR4-2133 nECC RAM
HP 16 GB (2 x 8 GB) DDR4-2133 nECC RAM
HP 8 GB (2 x 4 GB) DDR4-2133 nECC RAM
HP 8 GB (1 x 8 GB) DDR4-2133 nECC RAM
HP 4 GB (1 x 4 GB) DDR4-2133 nECC RAM
DDR4-2133 ECC Unbuffered DIMMs - CTO
HP 64 GB (4 x 16 GB) DDR4-2133 ECC RAM
HP 32 GB (4 x 8 GB) DDR4-2133 ECC RAM
HP 32 GB (2 x 16 GB) DDR4-2133 ECC RAM
HP 16 GB (2 x 8 GB) DDR4-2133 ECC RAM
HP 8 GB (1 x 8 GB) DDR4-2133 ECC RAM
DDR4-2133 non-ECC Unbuffered DIMMs - AMO
HP 16 GB (1 x 16 GB) DDR4-2133 non-ECC RAM
HP 8 GB (1 x 8 GB) DDR4-2133 non-ECC RAM
HP 4 GB (1 x 4 GB) DDR4-2133 non-ECC RAM
DDR4-2133 ECC Unbuffered DIMMs - AMO
HP 16 GB (1 x 16 GB) DDR4-2133 ECC RAM
Audio/multimedia
Feature
Audio
RealTec ALC3241-CG HD Audio Codec
Integrated Conexant CX7501 Audio Codec with DTS Studio Sound
Optical and removable storage
Feature
HP External Ultra-Slim DVD-RW Drive
Networking/communication
Feature
Networking
Integrated Intel I217LM PCIe GbE Controller (Intel vPro with Intel AMT 9.0)
Optional Intel 8260 Wireless LAN (802.11ac) and Bluetooth 4.2 Module
Input devices
Feature
Input devices
HP USB Business Slim Keyboard
HP USB Laser Scroll Mouse
Z1 HP No Keyboard
Z1 No Included Mouse
HP Wireless Business Slim KBD and Mouse
HP Performance Advisor
HP Remote Graphics Software (RGS) 6.0
Buy Office
Foxit PDF Solution
System board
Feature
Form factor
Custom Motherboard
Processor socket
Single LGA 1151
CPU bus speed
DMI Gen3
Intel PCH C236
Super I/O Controller
Nuvoton NPCD315H
Memory expansion slots
4 DDR4 SO-DIMM memory slots
Memory type supported
DDR4, UDIMM (Unbuffered), ECC & non-ECC
Memory modes
Non-Interleaved for single channel
Interleaved when both channels are populated
Memory speed supported
Up to 2300 MT/s DDR4
Maximum memory
64 GB ECC or 64 GB non-ECC
Memory configuration (supported)
4 GB, 8 GB, and 16 GB non-ECC/ 4 GB and 8 GB ECC unbuffered SO-DIMMs are supported.
ECC and non-ECC memory SO-DIMMs cannot be mixed on the same system.
PCI express connectors
1 MXM 3.1 slot (PCIe Gen3 x16 dedicated for graphics)
2 M.2 Socket 3 up to Type 2280-M H4.2
1 M.2 Socket 1 up to Type 3030-E H4.2 for WLAN
SATA
Integrated Serial ATA interfaces:
2 x 6 Gb/s SATA 3.0
Integrated graphics
Intel HD Graphics P530 (on select processors)
DirectX 11.1 compliant and OpenGL 4.0.
Integrated Graphics can support up to 3 displays: embedded display plus two external displays via either Rear IO or TBT.
Network controller
Integrated Ethernet PHY Connection I219LM. Management capabilities: WOL, PXE 2.1 and AMT 11.0
USB connector(s)
Side: 1 USB 3.0, 1 USB 3.0 Charging Data Port
Rear: 4 USB 3.0
Internal: 1 USB 2.0 Type A, 2 USB 2.0 across one 9-pin header (9-pin header is not available when the touch display option is selected)
HD integrated audio
Intel HD / Conexant CX7501 codec
Flash ROM
Yes
CPU fan header
Yes
Front control panel/speaker header
Yes
Integrated trusted platform module
Integrated TPM 2.0 TPM module disabled where restricted by law
Power supply headers
Yes
Power switch, power LED and hard drive LED header
Yes
Clear password jumper
Yes
Keyboard/mouse
USB
Power supply
Feature
Power supply
330W 90% Efficient, Custom PSU (Wide Ranging, Active PFC)
Operating voltage range
90-264 VAC
Rated voltage range
100-240 VAC
Rated line frequency
50-60 Hz
Operating line frequency range
47-63 Hz
Rated input current
5A at 100-240 VAC
Heat dissipation (configuration and software dependent)
Typical: 444 btu/hr (112 kg-cal/hr)
Maximum: 1126 btu/hr (284 kg-cal/hr)
Power supply fan
None
ENERGY STAR qualified (configuration dependent)
Yes
80 PLUS compliant
Yes, > 90% Efficiency at 50% Load 115VAC 60Hz
FEMP standby power compliant at 115V
Yes
ErP LOT6 compliant at 230V
<0.5 W in S5 - Power Off
Yes
CECP compliant at 220V
4W in S3 - suspend to RAM)
NA
Power consumption in sleep mode (as defined by ENERGY STAR) - suspend to RAM (S3) (instantly available PC)
<4W
Built-in self test LED
Yes
Surge tolerant full ranging power supply (withstands power surges up to 2000V)
Yes
Environmental
Feature
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: -40° to 60° C (-40° to 140° F)
Humidity
Operating: 8% to 85% RH, non-condensing
Non-operating: 8% to 90% RH, non-condensing
Maximum altitude
Operating: 3,000 m (10,000 ft)
Storage: 9,100 m (30,000 ft)
Dynamic (new)
Shock
Operating: ½-sine: 40g, 2-3ms (~62 cm/sec)
Non-operating: ½-sine: 160 cm/s, 2-3ms (~105g) square: 422 cm/s, 20g
Vibration
Operating random: 0.5g (rms), 5-300 Hz, up to 0.0025 g²/Hz
Non-operating random: 2.0g (rms), 5-500 Hz, up to 0.0150 g²/Hz
Cooling
Above 1,524 m (5,000 ft) altitude, maximum operating temperature is derated by 1° C (1.8° F) per 305 m (1,000 ft) elevation increase.
