Inserting the SD card tray upside down can damage the slot. Care must be taken to insert the SD card tray properly.
Figure 1. Correct (checkmark) and incorrect (X) tray insertion
NOTE: computers manufactured beginning 01 September 2016 and later have a design change that prevents improper insertion of the SD card tray.
