    Looking for Site Help?
HP V245h 23.8-inch Monitor - Specifications
Panel
Specification
Part numbers
W6M76AA
Type
IPS with LED backlight
Native resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Brightness
250 cd/m2
Contrast ratio (typical)
1000:1
Dynamic contrast ratio (typical)
10,000,000:1
Pixel pitch
0.2745 x 0.2745 mm
Backlight lamp life (to half brightness)
30,000 hours minimum
Anti-Glare
Yes
Response rate (typical)
7 ms (gray to gray)
Color gamut (typical)
72%
Color support
16.7 million colors
Horizontal viewing angle
178°
Vertical viewing angle
178°
Panel active area
52.70 x 29.64 cm (20.04 x 11.66 in)
Signal interface/performance
Specification
Horizontal frequency
24 to 80 kHz
Vertical frequency
50 to 76 Hz
Preset VESA Graphic Modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Default color temperature
6,500 K
Maximum pixel clock speed
170 MHz
User controls
Specification
Buttons or switches
1. Main Menu, Next or Enter, Select
2. Brightness, Minus or Down, Quick View Menu
3. AUTO, Plus or Up, Quick View
4. Back, Cancel or Exit
5. Power
Programmable modes
10
Languages
Chinese (Traditional), Chinese (Simplified), Dutch, English, French, German, Italian, Japanese, Portuguese, Spanish
Video and input connectors
Specification
Plug & play
Yes
Inputs
(1) VGA, (2) HDMI (HDCP support on HDMI inputs)
Video Cable
(1) VGA
Video Cable length
1.8 m (5.9 ft)
Monitor specifications
Specification
Dimensions (W x D x H)
Unpacked with stand: 53.98 x 16.41 x 40.83 cm (21.25 x 6.46 x 16.08 in)
Unpacked without stand: 53.98 x 5.06 x 32.73 cm (21.25 x 2 x 12.89 in)
Packaged: 62 x 14 x 42 cm (24.4 x 5.5 x 16.5 in)
Unpacked with stand: 4.3 kg (9.5 lb)
Unpacked without stand: 3.11 kg (6.89 lb)
Packaged: 6.05 kg (13.34 lb)
Tilt range
- 2° to + 25° vertical
Swivel range
N/A
Height adjustment
N/A
Pivot rotation
N/A
Base
Detachable
Power
Specification
Power supply
External
Input power
100 - 240 VAC (50/60 Hz)
Typical power consumption
24 watts
Maximum
26 watts
Energy saving mode
0.5 watts
Power cable length
1.9 m (6.2 ft)
Operating conditions
Specification
Temperature
5° to 35° C (41° to 95° F)
Non-operating temperature
-20° to 60° C (-4° to 140° F)
Operating humidity
10% to 70%
Non-operating humidity
10% to 90%
Country: Flag Thailand
