HP V192b 18.5-inch Monitor - Specifications
Panel
Specification
Type
TN with LED backlight
46.99 cm (18.5 in) widescreen, diagonally measured
Panel active area (W x H)
40.98 x 23.04 cm (16.13 x 9.07 in)
Resolution
1366 x 768 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 170° horizontal
Up to 160° vertical
Brightness
250 cd/m2
Contrast ratio (typical)
1000:1
Response rate (typical)
5 ms (on/off)
Pixel pitch
0.3 mm
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Can display up to 16.7 million colors
Color gamut (typical)
72%
On Screen Display (OSD)
Specification
Buttons or switches
Menu
Reader
Function
Auto
Exit
Power
Programmable modes
20
Languages
Brazilian Portuguese, Chinese (simplified), Chinese (traditional), English, Finnish, Hindi, French, German, Greek, Italian, Japanese, Korean, Polish, Portuguese, Russian, Spanish, Swedish, Ukrainian
On-screen display (OSD) user controls
Brightness, Contrast, Sharpness, Color, Display, Language, Reset
Signal interface/performance
Specification
Horizontal frequency
30 to 61 kHz
Vertical frequency
56 to 75 Hz
Native resolution
1366 x 768 at 60 Hz
Preset graphic modes (non-interlaced)
1280 X 1024 at 60 Hz
1280 x 800 at 60 Hz
1280 X 720 at 60 Hz
11024 X 768 at 60 Hz
800 X 600 at 60 Hz
720 X 400 at 70 Hz
Maximum pixel clock speed
90 MHz
Anti-glare
Yes
Default color temperature
6,500 K
Video/other inputs
Specification
Plug and play
Yes
Input signal
VGA
Video Cables included
1.8 m (5.9 ft) VGA cable
Power
Specification
Power supply
External
Input power
100 to 240 VAC (50/60 Hz)
Maximum power
19 W
Typical power
24 W
Power saving
Less than 0.5 W
Power cable length
1.8 m (4.9 ft)
Mechanical
Specification
Dimensions (W x D x H)
Unpacked with stand: 44.13 x 17.87 x 37.94 cm (17.37 x 7.04 x 14.94 in)
Unpacked without stand (head only): 44.13 x 6.04 x 27.81 cm (17.37 x 2.38 x 10.95 in)
Packaged: 50 x 33.3 x 10.4 cm (19.6 x 13.1 x 4.1 in)
Head only: 1.9 kg (4.18 lb)
Unpacked with stand: 2.1 kg (4.6 lb)
Packaged: 3.2 kg (7 lb)
Tilt range
-5° to +20° vertical
Base
Detachable
Environmental
Specification
Temperature
Operating: 10° to 35° C (50° to 95° F)
Non-operating: 20° to 60° C (-29° to 140° F)
Humidity
Operating: 5% to 90% (non-condensing)
Non-operating: 10% to 80%
Altitude
Operating: 0 to 5,000 m (0 to 16,404 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
No
Mercury-free display backlighting
Yes
