HP Notebook - 14-ac103nia (ENERGY STAR) Product Specifications
K3E97EA
Intel® Core™ i5-6200U with Intel® HD Graphics 520 (2.3 GHz, up to 2.8 GHz, 3 MB cache, 2 cores)
6 GB DDR3L SDRAM (1 x 2 GB, 1 x 4 GB)
Video Graphics
AMD Radeon R5 M330 Graphics (2 GB DDR3 dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
35.6 cm (14") diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 VGA; 1 HDMI; 1 headphone/microphone combo; 2 USB 2.0; 1 USB 3.0; 1 RJ-45
34.54 x 24.15 x 2.39 cm
1.94 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™ with 2 speakers
HP 3D DriveGuard
Pre-installed software
Evernote; Skype
