Remove and Replace the Wireless Module on the HP Pavilion x2 Detachable 12-b000 Notebook
This document applies to HP Pavilion x2 Detachable 12-b0000 Notebook.
Before you begin
  • Have available a non-marring flat-bladed prying tool and tweezers or pliers.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Removing and replacing parts or wires and servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of the tablet. These same removal and replacement procedures apply to all configurations of HP Pavilion x2 Detachable 12-b0000 notebooks.
Removing the wireless module
Depending on your notebook's configuration, you may have either a WLAN or WLAN/Bluetooth Combo module. However, the removal and replacement of these modules is identical.
Use the steps in this section to remove the wireless module.
Step 1
Remove the display panel assembly.
The display panel assembly
Step 2
Carefully disconnect the wireless antenna cables from the wireless module by grasping the connector with a small pair of needle nose pliers or tweezers.
Make careful note of which terminal the wireless antenna cables are connected to on the wireless module for later replacement.
Disconnecting the wireless antenna cables
Step 3
Remove the 3 mm P1 Phillips-head screw that secures the wireless module to the display enclosure.
Removing the screw that secures the wireless module
Step 4
Grasp the wireless module by the edges and pull gently to remove it.
Step 5
Place the wireless module in a static dissipative bag.
Placing the wireless module in a static dissipative bag
Replacing the wireless module
Use the steps in this section to replace the wireless module.
Step 1
Grasping the wireless module by the edges, align the notch in the wireless module with the key in the wireless module slot on the system board.
Aligning the notch in the module with the key in the slot
Step 2
Gently insert the wireless module into its slot on the system board.
Inserting the wireless module
Step 3
Replace the 3 mm P1 Phillips-head screw that secures the wireless module to the display enclosure.
Replacing the screw that secures the wireless module
Step 4
Reconnect the wireless antenna cables to the wireless module.
Reconnecting the wireless antenna cables
Step 5
Replace the display panel assembly.
The display panel assembly to replace
