Remove and Replace the Display Panel Cable on the HP Pavilion x2 Detachable 12-b000 Notebook
This document applies to HP Pavilion x2 Detachable 12-b0000 Notebook.
Before you begin
  • Have available a non-marring flat-bladed prying tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Removing and replacing parts or wires and servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of the tablet. These same removal and replacement procedures apply to all configurations of HP Pavilion x2 Detachable 12-b0000 notebooks.
Removing the display panel cable
Use the steps in this section to remove the display panel cable.
Step 1
Remove the display panel assembly.
The display panel assembly
Step 2
Using minimal force, lift the locking bar up on the display panel ZIF connector and disconnect the display panel ribbon cable from the touchscreen control board.
Make careful note of the routing of the display panel cable for later replacement.
Use care to prevent damaging the ZIF connector and ribbon cable.
Lifting the locking bar on the display panel ZIF connector
Step 3
Peel back the retention tape...
Peeling back the retention tape
...and disconnect the display panel cable from its connector on the display panel.
Disconnecting the display panel cable from its connector
Step 4
Peel back the retention tape that secures the display panel cable to the display panel assembly.
Step 5
Remove the display panel cable from the adhesive that secures it to the display panel assembly.
Replacing the display panel cable
Use the steps in this section to replace the display panel cable.
Step 1
Insert the display panel cable into its connector on the display panel...
Inserting the display panel cable into its connector
...and replace the retention tape.
Replacing the retention tape
Step 2
Insert the display panel ribbon cable into the display panel ZIF connector on the touchscreen control board and press the locking bar down to lock the cable into place.
Inserting the display panel ribbon cable into the ZIF connector
Step 3
Apply pressure to the length of the display panel cable to adhere it to the display panel assembly.
Pressing the cable to adhere it to the panel assembly
Step 4
Replace the retention tape that secures the display panel cable to the display panel assembly.
Step 5
Replace the display panel assembly.
The display panel assembly to replace
Country: Flag Thailand
