HP ENVY Notebook - 17-r005tx Product Specifications
T0X69PA
Intel® Core™ i7-6700HQ with Intel® HD Graphics 530 (2.6 GHz, 6 MB cache, 4 cores)
8 GB DDR3L-1600 SDRAM (2 x 4 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
17.3" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size backlit keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
External Ports
4 USB 3.0; 1 HDMI; 1 micro HDMI; 1 RJ-45; 1 headphone/microphone combo
41.5 x 28.13 x 3.07 cm
Starting at 1.36 kg
120 W AC power adapter
6-cell, 62 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen; Quad speakers with 1 subwoofer
Buy Office
HP Support Assistant; HP Recovery Manager; HP CoolSense; HP 3D DriveGuard; HP SimplePass
Pre-installed software
CyberLink YouCam; CyberLink PowerDirector; CyberLink PhotoDirector; Adobe® Shockwave® Player; CyberLink Power Media Player; User Guide documentation; iPass; Evernote; Dropbox
