Product description
HP Officejet 5745 e-All-in-One Printer B9S80A
- ${title}
- ${title}
- ${title}
- ${title}
HP Officejet 5745 e-All-in-One Printer (B9S80A) Specifications
Product Naming
Connectivity
Direct print supported
Wireless direct printing; Memory card slot; USB printing
Wireless capability
Yes
Connectivity, standard
2 USB 2.0; 1 Wi-Fi 802.11b/g/n; 1 Ethernet; 1 RJ-11 fax
Copy
Copy speed black (draft, A4)
Up to 21 cpm
Copy speed color (draft, A4)
Up to 19 cpm
Copies, maximum
Up to 50 copies
Copy reduce / enlarge settings
25 to 400%
Color copy capability
Yes
Copier settings
Number of Copies; 2-Sided; Draft; Black; Color; Quality; Resize; Lighter/Darker; Paper Size; Paper Type; Margin Shift; Enhancements; Set as New Defaults
Environmental
Operating humidity range
20 to 80% RH
Storage humidity
10 to 90% RH (non-condensing)
Storage temperature range
-40 to 60º C (-40 to 140º F)
Recommended operating temperature range
5 to 35º C (41 to 95º F)
Acoustic power emissions
6.4 B(A) (printing at 6 PPM)
Environmental specifications
Save paper by up to 50% using automatic two-sided printing. Free, convenient cartridge recycling in 48 countries. http://www.hp.com/recycle
Fax
Fax note
Based on standard ITU-T test image #1 at standard resolution. More complicated pages or higher resolution will take longer and use more memory.
Fax transmission speed
33.6 kbps (fast), 14.4 kbps (medium), and 9.6 kbps (slow)
Fax resolution
Up to 300 x 311 dpi
Fax forwarding
Yes
Speed dials, maximum number
Up to 99 numbers
Polling
No
Distinctive ring detection supported
Yes
Junk fax barrier
Yes, requires Caller ID
Auto redial
Yes
Fax memory (A4)
Up to 100 pages in black and white
Fax delayed sending
Yes (black only)
Remote retrieval
No
Fax memory (Letter)
Faxing
Yes, color
PC interface supported
Yes, PC send and PC archive
Auto fax reduction supported
Yes
Modem speed
Up to 33.6 kbps
Ink Cartridges/Toner Cartridges
SureSupply note
HP SureSupply alerts you when you should replace a print cartridge and helps you purchase locally or via the Internet. For more information, visit http://www.hp.com/learn/suresupply. Only available with original HP supplies; Internet access required.
Replacement cartridges
HP 62 Black Ink Cartridge (~200 pages); HP 62 Tri-color Ink Cartridge (~165 pages); HP 62XL Black Ink Cartridge (~600 pages); HP 62XL Tri-color Ink Cartridge (~415 pages). [Average based on ISO/IEC 24711 or HP testing methodology and continuous printing. Actual yield varies considerably based on content of printed pages and other factors. For details see http://www.hp.com/go/learnaboutsupplies]
Number of print cartridges
2 (1 black, 1 Tri-color [cyan, magenta, yellow])
Memory device
Memory card compatibility
Secure Digital, USB flash drive
Mobile Printing Capability
Mobile printing compatibility note
Wireless performance is dependent upon physical environment and distance from the access point. Wireless operations are compatible with 2.4 GHz routers only; excludes wireless direct. Wireless direct may require driver or apps be installed and connected on wireless-enabled mobile device or PC. Wireless functionality may vary by computer and mobile operating systems, see hpconnected.com. HP ePrint requires: account registration, HP ePrint-enabled printer, Internet connection, and a wireless-enabled mobile device or Internet-connected computer with email capability. Separately purchased data plans or usage fees may apply. Print times and connection speeds may vary. AirPrint supports OS X® Lion, OS X® Mountain Lion and the following devices running iOS 4.2 or later: iPad®, iPhone® (3GS or later), iPod touch® (3rd generation or later) and requires the printer be connected to the same network as your OS X or iOS device. AirPrint, the AirPrint Logo, iPad, iPhone, and iPod touch are trademarks of Apple® Inc. Windows is a trademark of the Microsoft group of companies. BlackBerry® names and logos are the property of Research In Motion Limited. Android is a trademark of Google Inc.
Mobile printing capability
Features Wi-Fi Direct and local Wi-Fi connectivity to enable mobile printing via HP ePrint, Apple AirPrint™ as well as other solutions. Supports printing from most smartphones and tablets using these operating systems: Android, iOS, Blackberry, Windows® 8, Windows RT.
Network Protocol
Network protocols, supported
TCP/IP
Paper Handling
Media weight, supported (metric)
Tray 1: A4: 75 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP Photo Paper: up to 250 g/m²; HP 10 x 15 cm photo paper: up to 250 g/m²
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media weight, supported (U.S. standard)
16 to 72 lb
Media sizes supported (U.S. standard)
Letter, Legal, 4 x 6 in, 5 x 7 in, 8 x 10 in, No. 10 envelopes
Duplex options
Automatic
Maximum print area
209.9 x 349.6 mm (8.3 x 13.8 in)
Standard input capacity (secondary tray)
Up to 15 sheets
Standard input capacity (envelopes)
Up to 5
Input capacity
Up to 125 sheets
Output capacity
Up to 25 sheets
Standard input capacity (Legal)
Up to 125 sheets
Envelope input capacity
Up to 5 envelopes
Standard input capacity (transparencies)
Up to 40 sheets
Standard input capacity (cards)
Up to 40 cards
Paper handling - ADF
Media sizes, custom
76 x 127 to 216 x 356 mm (3 x 5 to 8.5 x 14 in)
Maximum scan size (ADF)
216 x 356 mm (8.5 x 14 in)
Automatic document feeder capacity
Standard, 25 sheets
Paper Handling - Duplexer
Duplexer media sizes
Letter, Executive [all media lengths between 140 and 310 mm (5.5 and 12.2 in)]
Physical Dimensions
Maximum dimensions (W x D x H)
454 x 503 X 193 mm (17.8 x 19.8 x 7.6 in)
Power
Built-in Universal Power Supply
Power consumption
5.25 watts (Ready), 1.18 watts (Sleep), 0.25 watts (Off)
Power supply
Input voltage 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)[8]
Energy savings feature technology
HP Auto-Off Technology
Printing Specifications
Print languages
HP PCL 3 GUI
Duty cycle (monthly, Letter)
Up to 1000 pages
Print technology
HP Thermal Inkjet
Print speed black (draft, Letter)
Up to 22 ppm
Print speed black (ISO)
Up to 12 ppm
Print speed color (ISO)
Up to 8 ppm
Print speed color (draft, Letter)
Up to 21 ppm
Print quality black (best)
Up to 1200 x 1200 rendered dpi (when printing from a computer)
Print quality color (best)
Up to 4800 x 1200 optimized dpi color (when printing from a computer on selected HP photo papers and Print in Max dpi)
Regulatory Specifications
Safety
IEC 60950 -1: 2005+ A1:2009/EN 60950-1: 2006+A11: 2009 +A1:2010 +A12:2011; IEC 62479:2010/EN 62479:2010; IEC 62311: 2007/EN 62311: 2008; Australia/New Zealand AS/NZS 60950.1: 2011; Canada/America CAN/CSA-C22.2 No 60950-1-07, Amendment 1:2011, Low Voltage Directive 2006/95/EC with CE Marking (Europe); ; Singapore PSB; Korea KCC; Taiwan BSMI; Other safety approvals as required by individual countries.
Energy efficiency
ENERGY STAR® qualified
Electromagnetic compatibility
CISPR 22:2008 / EN 55022:2010 (Class B), CISPR24:2010/EN 55024:2010, EN 301 489-1 v1.9.2: 2011, EN 301 489-17 v2.2.1: 2012, EN 61000-3-2 :2006 +A1:2009 +A2:2009, EN 61000-3-3: 2008, EMC Directive 2004/108/EC with CE Marking (Europe), FCC Part 15 Rules Class B (USA), ICES-003 Issue 5 (Canada), EN 55022:2006 (Australia/New Zealand), VCCI V-3 2013.04 (Japan), KKC certified (Korea), CNS 13438:2006 (Taiwan BSMI)
Regulatory model number
SDGOB-1401-02
Scan
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Scan size (flatbed), maximum
216 x 297 mm (8.5 x 11.7 in)
Scan technology
CIS
Twain version
Version 1.9
Scanning options (ADF)
Single-Sided
System Requirements
Recommended system requirements
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Windows Vista: 800 MHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer. Windows XP SP3 or higher (32-bit only): any Intel® Pentium® II, Celeron® or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 6.
Minimum system requirements
Recommended Macintosh system requirements
Mac OS X Lion, OS X Mountain Lion, OS X Mavericks; Intel® Core™ Processor; 1 GB HD; CD-ROM/DVD or Internet; USB
Minimum system requirements for Macintosh
OS X v10.7 Lion, OS X v10.8 Mountain Lion, OS X v10.9 Mavericks, 1 GB HD, Internet, USB
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
