Remove and Replace the Display Panel Assembly on the HP Pavilion x2 Detachable 12-b000 Notebook
This document applies to HP Pavilion x2 Detachable 12-b000 Notebook.
Before you begin
  • Have available a non-marring flat-bladed prying tool.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Removing and replacing parts or wires and servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of the tablet. These same removal and replacement procedures apply to all configurations of HP Pavilion x2 Detachable 12-b000 notebooks.
Removing the display panel assembly
Use the steps in this section to remove the display panel assembly.
Step 1
Using a non-marring flat-bladed tool, carefully release the display panel assembly from the display enclosure.
To prevent damage to the display enclosure, take extreme care when the flat bladed tool is near any of the external buttons or connectors.
Releasing the display panel assembly
Step 2
Lift the display panel assembly off of the display enclosure until you have access to the battery and display panel ZIF connectors.
Step 3
Disconnect the battery cable from its connector on the system board.
Disconnecting the battery cable
Step 4
Using minimal force, lift the locking bar up on the display panel ZIF connector and disconnect the display panel ribbon cable from the system board.
Use care to prevent damaging the ZIF connectors and ribbon cables while performing the steps in this document.
Lifting the locking bar on the display panel ZIF connector
Step 5
Remove the display panel assembly.
Removing the display pane assembly
Replacing the display panel assembly
Use the steps in this section to replace the display panel assembly.
Step 1
Before installing a new display panel assembly, remove the display panel cable from the old display panel assembly and install it on the new display panel assembly.
Panel with the display panel cable outlined
Step 2
Place the display panel assembly in front of the display enclosure so that you have access to the display panel cable and ZIF connector.
Placing the display panel assembly in front of the display enclosure
Step 3
Insert the display panel ribbon cable into the display panel ZIF connector on the system board and press the locking bar down to lock the cable into place.
Inserting the display panel ribbon cable into the ZIF connector
Step 4
Insert the battery cable into its connector on the system board.
Inserting the battery cable into the connector on the system board
Step 5
Place the display panel assembly into position on the display enclosure.
Placing the display panel assembly into position
Step 6
Carefully press down on the edges of the display panel assembly to snap it into place.
Pressing and snapping the edges of the display panel assembly in place
