HP Notebook - 15-ac654tu Product Specifications
V5E16PA
Intel® Pentium® N3700 with Intel® HD Graphics (1.6 GHz, up to 2.4 GHz, 2 MB cache, 4 cores)
4 GB DDR3L SDRAM (1 x 4 GB)
Video Graphics
Intel HD Graphics
Hard Drive
500 GB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD anti-glare LED-backlit (1920 x 1080)
Keyboard
Island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo
External Ports
1 USB 3.0; 2 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.43 x 25.46 x 2.43 cm
Starting at 2.19 kg
45 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
DTS Studio Sound™; Dual speakers
FreeDOS 2.0
