HP OfficeJet Pro 8210 Printers - 'Paper Jam' Error
This document is for the HP OfficeJet Pro 8210, 8216, and 8218 printers.
During a print job, the printer stops feeding pages and a Paper Jam error message displays on the printer control panel indicating paper might be jammed inside the printer.
Paper jams can be real or false. The printer might report a paper jam even when there is no jammed paper. The following steps apply to both real and false paper jams.
You need a flashlight to complete some of these steps.
Figure : Flashlight
Image: Flashlight
Step 1: Clear jammed paper from the printer
Paper jams can occur in multiple areas of the printer. If you cannot find the paper jam in one area, continue to the next area until the jam is located.
If you have checked and removed any jammed paper from each printer area and the error persists, continue to the next step.
Step 2: Make sure the carriage can move freely
Make sure the carriage moves freely across the width of the printer.
  1. On the printer control panel, press OK on the error screen.
    The printer tries to clear the jam automatically.
    If the paper jam error persists, continue these steps to manually clear the jam.
  2. Open the ink cartridge access door.
    Figure : Opening the ink cartridge access door
  3. Wait until the carriage is idle and silent before you continue.
  4. With the printer turned on, disconnect the power cord and any other cables.
      warning:
    You must unplug the power cord to move the carriage by hand and reset the paper feed mechanism without the risk of electrical shock.
  5. Use a flashlight and look inside the printer.
  6. Firmly push the carriage to the left and to the right, and then remove any objects blocking the carriage path. If removing whole sheets of paper, pull the paper with both hands.
    Figure : Moving the carriage
    Moving the carriage left to right
  7. Close the ink cartridge access door.
  8. Reconnect the power cord and any other cables to the rear of the printer, and then turn on the printer.
Try to print. If the error persists, continue to the next step.
Step 3: Clean the paper feed rollers
Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Clean the rollers inside the printer, and then try to print again.
Gather the following materials:
  • A clean, lint-free cotton swab
  • Distilled or bottled water
    Do not use tap water because it might contain contaminates that can damage the printhead.
If you have cleaned the rollers in each printer area and the error persists, continue to the next step.
Step 4: Reset the printer
Sometimes, the printer can display an error message even after the issue has been resolved. Reset the printer to clear the error.
  1. With the printer turned on, disconnect the power cord from the printer.
  2. Unplug the power cord from the power source.
  3. Wait 60 seconds.
  4. Reconnect the power cord to a wall outlet and to the printer.
    HP recommends plugging the printer directly into a wall outlet.
Step 5: Service the printer
If the steps in this document did not resolve the issue, service the printer.
Service or replace your HP product if the issue persists after completing all the preceding steps.
Go to Contact HP Customer Support to schedule a product repair or replacement. If you are in Asia Pacific, you will be directed to a local service center in your area.
To confirm your warranty status, go to HP Product Warranty Check. Repair fees might apply for out-of-warranty products.
