HP 340, 348 G3 Notebook PC - Specifications
Operating systems
Feature
Preinstalled
Windows 10 Pro 64
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro 64)
Windows 7 Home Basic 6 (China only)
Neokylin Linux
Processors
Feature
Intel SoC (chipset is integrated with processor)
Intel Core i7-6500U with Intel HD Graphics 520
2.5 GHz with Intel Turbo Boost Technology
4 MB cache
2 cores
Intel Core i5-6200U with Intel HD Graphics 520
2.3 GHz, up to 2.8 GHz with Intel Turbo Boost Technology
3 MB cache
2 cores
Intel Core i3-6100U with Intel HD Graphics 520
2.3 GHz
3 MB cache
2 cores
Intel Celeron 3855U with Intel HD Graphics 510
1.6 GHZ
2 MB cache
2 cores
Graphics
Feature
Graphics
Intel HD Graphics
Discrete
AMD Radeon R5 M330 (2 GB DDR3 dedicated, switchable)
Displays
Feature
Internal
14 in diagonal HD eDP anti-glare Slim LED-backlit (1366 x 768)
14 in diagonal FHD eDP anti-glare Slim LED-backlit (1920 x 1080)
External
Up to 32-bit per pixel color depth
VGA
Port supports 1080p external resolution at 60 Hz
HDMI
v1.4b Supporting up to 1920 x 1200 at 60Hz
Storage and drives
Feature
Hard drives
500 GB 7200 rpm SATA Hard Drive
500 GB - 5400 RPM SSHD (8GB Cache)
256 GB 2280 TLC M.2 SSD (HP 348 only)
1 TB 7200 rpm SATA Hard Drive
Optical drives
DVD+/-RW SuperMulti DL Drive (optional)
Memory
Feature
Standard
DDR4 - 2133 (Transfer rates up to 2133 MT/s)
Dual Channel Support
Memory is non customer accessible or upgradeable
Supports
4096 MB (4096 x 1)
8192 MB (8192 x 1)
16384 MB (8192 x 2)
Maximum
Up to 16 GB
Networking/communications
Feature
Wireless
802.11b/g/n (1 x 1) and Bluetooth 4.0 Combo
802.11a/b/g/n (2 x 2) and Bluetooth 4.0 Combo
Communications
Realtek Ethernet (10/100/1000) NIC (On select models)
Audio/multimedia
Feature
Audio
DTS Studio Sound
Dual speakers
Dual digital microphone on webcam configuration
Single digital microphone for non-webcam configuration
640 x 480 by 24 frames per second
HD camera - Fixed (no tilt) (select models)
1280 x 720 by 30 frames per second
Keyboard and pointing devices
Feature
Keyboard
Full-sized spill resistance keyboard
Pointing devices
Touchpad with multi-touch gestures enabled
Taps enabled as default
Default on for 2-finger scroll and pinch
Software and security
Feature
Preinstalled
Buy Office
Cyberlink Media Suite
Cyberlink Power DVD (available on select models) 2Go Desktop
Cyberlink PowerDVD/Power Media Player 12 (On select models)
McAfeeTM Central-Metro
McAfeeTM LiveSafe
Snapfish
Security
Firmware TPM
Security Lock slot (Lock sold separately)
Power
Specification
Power supply
HP 65W EM Smart AC adapter (China)
Primary Battery
4-cell, 41 WHr Li-ion4-cell, 40 WHr Li-ion LLB type
6-cell, 47 WHr Li-ion
Battery
HP Long Life 3-cell
56 WHr Li-ion
Weight and dimensions
Specification
Starting at 2 kg (4.4 lb)
Weight will vary by configuration
Dimensions (W x D x H)
34.54 x 24.15 x 2.39 cm (13.59 x 9.51 x .09 in)
Ports/slots
Specification
Ports and slots
(4) USB 3.0 Ports
(1) VGA
(1) HDMI (Cable not included)
(1) Headphone / microphone-in combo jack
(1) AC power
(1) RJ-45
Digital Media Slots
Supports SD/SDHC/SDXC
Supports mini versions with adapter
