    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP V225hz 21.5-inch Monitor - Specifications
Panel
Specification
Type
21.5-inch diagonal IPS
54.61 cm (21.5 in) widescreen, diagonally measured
Panel active area (W x H)
49.71 x 26.78 cm (19.57 x 10.54 in)
Resolution
1920 x 1080 at 60Hz
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal
178° vertical typical
Brightness
250 cd/m
Contrast ratio (typical)
1000:1 Static; 5,000,000:1 Dynamic (DCR)
Response time (typical)
8 ms (on/off)
Pixel pitch
.08 x .24 mm
Pixel pitch inch
102.46 DPI
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Can display up to 16.7 million colors
Color gamut (typical)
72%
User controls
Specification
Buttons or switches
Menu
Reader
Energy Saving
Auto
Input/Exit
Power
Programmable modes
20
Languages
Chinese, English, French, Germanic, Greek, Hindi, Italian, Japanese, Korean, Portuguese, Brazilian Portuguese, Finnish, Polish, Russian, Spanish, Swedish, Ukrainian
On-screen display (OSD) user controls
Brightness, Contrast, Color, Wide/Original, Reset, Sharpness, Gama, Color Temperature, H Position, V Position, Clock, Phase, Language, Power Indicator, Resolution
Signal interface/performance
Specification
Horizontal frequency
30 - 83 kHz
Vertical frequency
56 - 75 Hz
Native resolution
1920 x 1080 at 60 Hz
Preset graphic modes (non-interlaced)
640 x 480 at 60Hz
640 x 480 at 75Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
800 x 600 at 75 Hz
1024 x 768 at 60 Hz
1024 x 768 at 75 Hz
1152 x 864 at 75 Hz
1280 x 1024 at 60 Hz
1280 x 1024 at 75 Hz
1680 x 1050 at 60Hz
1920 x 1080 at 60Hz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input connectors
(1) DisplayPort
(1) VGA (D-SUB)
(1) DVI-D
USB
N/A
Cables included
VGA and DisplayPort cables 1.8 m (4.9 ft)
Power
Specification
Power supply
Internal
Input power
110 to 220 VAC at 50/60 Hz
Maximum power
27 W
Typical power
20 W
Sleep power
0.3 W
Power cable length
1.9 m (6.2 ft)
Mechanical
Specification
Dimensions (W x D x H)
Unpacked with stand: 50.8 x 22.4 x 35.6 cm (20.0 x 8.82 x 14.02 in)
Unpacked without stand (head only): 50.8 x 15.0 x 31.2 cm (20 x 5.91 x 12.28 in)
Packaged: 57.2 x 37 x 17.8 cm (22.52 x 14.57 x 7.01 in)
Head only: 3.9 kg (8.6 lb)
Unpacked with stand: 4.3 kg (9.48 lb)
Packaged: 5.5 kg (12.6 lb)
Tilt range
-5° to + 20° vertical
Swivel
N/A
Height adjustment
Yes, 110 mm
Pivot
Yes, 90°
Environmental
Specification
Temperature
Operating: 10° to 35° C (50° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 10% to 80%
Non-operating: 5% to 90% non-condensing
Altitude
Operating: 0 to 3,000 m (0 to 9,842.52 ft)
Non-operating: 0 to 5,000 m (0 to 16,404.2 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
No
Mercury-free display backlighting
Yes
Miscellaneous
Specification
User guide languages
Warranty languages
Color
Black
VESA mounting
100 mm VESA mount
Security lock-ready
Yes
Country of origin
Brazil
