HP Spectre Pro x360 G2 Convertible PC Specifications
Product description
Figure : HP Spectre Pro x360 G2 Convertible PC
Processors
Feature
Integrated with processor
Intel Core i7-6600U with Intel HD Graphics 520 (Available with iAMT (vPro))
2.6 GHz, up to 3.2 GHz with Intel Turbo Boost Technology, 4 MB cache, 2 cores
Intel Core i5-6300U with Intel HD Graphics 520
2.3 GHz, up to 2.9 GHz with Intel Turbo Boost Technology, 3 MB cache, 2 cores
Intel Core i5-6200U with Intel HD Graphics 520 (Available with iAMT (vPro), config with 8 GB only)
2.2 GHz, up to 2.7 GHz with Intel Turbo Boost Technology, 3 MB cache, 2 cores
Graphics
Feature
Graphics
Displays
Feature
Touchscreen
13.3-inch diagonal FHD UWVA WLED BrightView (1920 x 1080) eDP 1.2
13.3-inch diagonal QHD UWVA WLED BrightView (2560 x 1440) eDP1.3+PSR
External
Up to 32-bit per pixel color depth
HDMI
v1.4b Supporting up to 1920 x 1200 at 60Hz
Storage and drives
Feature
Solid State Drives
128 GB SSD 2280 DS TLC / SATA
180 GB SSD 2280 DS MLC / SATA
256 GB SSD 2280 DS TLC / SATA
512 GB SSD 2280 DS TLC/ SATA
Self Encrypting Drive
256 GB SSD 2280 DS MLC / SATA-3 Self Encrypting Drive
Memory
Feature
Standard
LPDDR3-1600 (Transfer rates up to 1600 MT/s)
Dual Channel Support
Memory soldered down
Supports
4096 MB (128 M x 2 x 32 x 4PCs ) - 1600 MT/s
8192 MB (256 M x 4 x 16 x 4PCs ) - 1600 MT/s
Maximum
8 GB
Ports/slots
Specification
Ports and slots
(3) USB 3.0 Ports (2 at left; 1 at right)
(1) Mini DisplayPort 1.2
(1) HDMI (Cable not included)
(1) Headphone output & microphone input combo jack
(1) AC power adapter plug
HP multi-format digital media card reader
Support SD/SDHC/SDXC
Push-Push Insertion/Removal
Internal card expansion
One NGFF slot (2230) for WLAN
One NGFF slot (2280) for Solid State Drive
Networking/communications
Feature
Wireless LAN (WLAN)
Intel 802.11a/b/g/n/ac (2 x 2) and Bluetooth 4.0 Combo (Supports vPro)
Communications
Miracast support
Intel WiDI Pro Support
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
HP Noise Reduction Software
Digital Microphones (Dual Array)
Dual Speakers
HP TrueVision Full HD camera
Fixed (no tilt) + activity LED
1 Piece
USB 3.0
M-JPEG
Wide FOV(88 degree)
1920 x 1080 by 30 frames per second
Dual array Digital Microphones
With appropriate software - beam forming, echo cancellation, noise suppression
Power
Specification
Power supply
HP 45 W Smart AC adapter
HP 45 W Smart AC 2-prong adapter (Japan only)
AC and DC power cords
1.8 m (5.9 ft)
Battery
HP Long Life 3-cell
56 WHr Li-ion
Physical specifications
Specification
QHD Display + 3 cell battery + single mSATA : starting at 1.44 kg (3.17 lb)
FHD Display + 3 cell battery + single mSATA: Starting at 1.48 kg (3.26 lb)
Dimensions (W x D x H)
325 x 218 x 15.4 mm (12.79 x 8.58 x .61 in) (Front)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components.
Software and security
Specification
HP value add software
HP Touchpoint Manager
HP Wireless Hotspot
HP Support Assistant
HP ePrint
Multimedia
Cyberlink PowerDVD / Power Media Player 12
Collaboration
Skype RTC Insertion
mysms-Metro (Windows 8.1 only)
Third party
Buy Office
Adobe Shockwave Player
Foxit PhantomPDF Express for HP
Photos and videos
Intel Wireless display (WiDi)
Intel WiDi Pro
Cyberlink Youcam (Windows 7 only)
HP PageLift
Security
Absolute Data Protect
MS BitLocker
Operating systems
Feature
Preinstalled
Windows 10 Pro 64
Web-only support
Windows 10 Pro 64
Windows 10 Enterprise 64
Windows 8.1 64
Windows 8.1 Professional 64
Windows 8.1 Chinese Market 64
Windows 8.1 Emerging Markets 64
Windows 8.1 Multi-Language 64
Windows 7 Enterprise 64
Windows 7 Professional 64
