P3K99EA
HP ENVY Notebook - 15-ae108nf (ENERGY STAR)
Intel® Core™ i7-6500U with Intel® HD Graphics 520 (2.5 GHz, up to 3.1 GHz, 4 MB cache, 2 cores)
8 GB DDR3L SDRAM (1 x 8 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit with numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
Integrated 10/100/1000 Gigabit Ethernet LAN
External Ports
1 HDMI; 1 headphone/microphone combo; 4 USB 3.0 (1 HP USB Boost); 1 RJ-45
38.4 x 25.5 x 2.29 cm
2.36 kg
90 W AC power adapter
3-cell, 55.5 Wh Li-ion prismatic
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
Bang & Olufsen with 4 speakers and 1 subwoofer
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY Notebook - 15-ae108nf (ENERGY STAR) Product Specifications
HP Lounge; HP SimplePass; HP 3D DriveGuard
Pre-installed software
Evernote; Netflix; Skype
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
