HP Pavilion Notebook - 15-ab125nia (ENERGY STAR) Product Specifications
T8R99EA
AMD Quad-Core A6-6310 APU with Radeon R4 Graphics (1.8 GHz, up to 2.4 GHz, 2 MB cache)
Flash cache
8 GB
6 GB DDR3L SDRAM (1 x 2 GB, 1 x 4 GB)
Video Graphics
AMD Radeon R7 M360 Graphics (2 GB DDR3 dedicated)
Hard Drive
1 TB 5400 rpm SATA SSHD
Optical drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal HD BrightView WLED-backlit (1366 x 768)
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth® 4.0 combo (Miracast compatible)
External Ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
38.45 x 26.11 x 2.52 cm
2.29 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY; Dual speakers
HP 3D DriveGuard
Pre-installed software
Evernote; Skype
