    Windows 11 Upgrade Guide
Document ID: c04947524
Version: 1
Advisory: HP Z240 Workstation - Certain Windows 7 OS Media May Cause USB Keyboard and Mouse To Not Function
Release date : 21-Jan-2016
Last updated : 21-Jan-2016
DESCRIPTION
Z240 needs the below Win7 OSDVD part numbers to recover the system. A small number of systems shipped from the factory could contain old Windows 7 OSDVD media that cause USB keyboard and mouse to not function after installation is completed.
Our Recovery Media vendor that sends out the OSDVD is also impacted and should have the correct media by January 18th, 2016.
PS2 keyboard and mice will not be impacted.
The following list are the OSDVD part numbers that needs to be used to correct this issue:
W7 Pro 64bit
650434-254
650434-374
650434-DN4
650434-AB4
650434-AA4
650435-A24
650434-A24
650434-K24
Any earlier part number (ex: 650434-xx3) will have this issue.
Symptoms:
Attempting to install the OS, using the impacted (650434-xx3) Windows 7 OS media, the USB keyboard and mouse will not function.
SCOPE
Systems:
  • HP Z240 Small Form Factor Workstation
  • HP Z240 Small Form Factor Workstation (ENERGY STAR)
  • HP Z240 Tower Workstation
  • HP Z240 Tower Workstation (ENERGY STAR)
Operating Systems:
  • Microsoft Windows 7 Professional (64-bit)
RESOLUTION
To resolve the issue there are two suggested paths:
1. Call into support to ask for the fixed OSDVD media that will be available on January 18th, 2016.
2. Use a PS2 keyboard and mouse to install the image from the OSDVD, if these are available. After the USB drivers are installed from the DRVDVD, all USB ports and devices will be working as expected.
Hardware platforms affected : HP Z240 Small Form Factor Workstation, HP Z240 Small Form Factor Workstation (ENERGY STAR), HP Z240 Tower Workstation, HP Z240 Tower Workstation (ENERGY STAR)
Support Communication Cross Reference ID : IA04947524
