Star Wars Special Edition Notebook - 15-an009tx Product Specifications
T5Q08PA
Intel® Core™ i5-6200U with Intel® HD Graphics 520 (2.3 GHz, 3 MB cache, 2 cores)
8 GB DDR3L SDRAM (1 x 8 GB)
Video Graphics
NVIDIA GeForce 940M (2 GB DDR3L dedicated)
Hard Drive
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD anti-glare LED-backlit (1920 x 1080)
Keyboard
Island-style keyboard with integrated numeric keypad
Pointing device
Wireless Connectivity
802.11a/b/g/n/ac (1x1) and Bluetooth® 4.0 combo (Miracast compatible); WiDi
External Ports
2 USB 3.0; 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38.45 x 26.11 x 2.52 cm
Starting at 2.09 kg
65 W AC power adapter
4-cell, 41 Wh Li-ion
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
B&O PLAY with 2 speakers
HP Support Assistant; HP Recovery Manager; HP CoolSense; HP 3D DriveGuard
Pre-installed software
CyberLink YouCam; CyberLink PowerDirector; CyberLink PhotoDirector; Adobe® Shockwave® Player; CyberLink Power Media Player; User Guide documentation; iPass; Evernote; Dropbox
Buy Office
