    Fix HP Printer issue on macOS
Printer Specifications for HP OfficeJet 200 Mobile Printers
This document is for the HP OfficeJet 200, 200c, 202, 202c Mobile printers.
Review this document for detailed technical data, such as model numbers, system requirements, print speeds, connectivity types, physical dimensions, ink cartridges, paper handling, and print specifications.
Figure : HP OfficeJet 200 Mobile Printer
Image: HP OfficeJet 200 Mobile Printer
Printer model
CZ993A
HP OfficeJet 200C Mobile Printer
L9B95A
HP OfficeJet 202 Mobile Printer
N4K99C
HP OfficeJet 202C Mobile Printer
N4L14C
Paper-handling specifications
Review the following tables to make sure you are using the correct paper types and sizes and are not overloading the input tray.
The following table contains the recommended maximum amount of paper to use in the input tray.
Location
Type
Capacity
Input tray
Paper
64 to 100 g/m2 (104 to 163 lb)
Up to 50
Up to 20
Photo paper
300 gsm2 (80 lb bond)
Envelopes
75 to 90 g/m2 (20 to 24 lb bond envelope)
Up to 5
Cards
Up to 200 g/m2 (110 lb index)
Up to 20
Hagaki
n/a
Up to 20
