Document ID: c04896599
Version: 1
Advisory: HP ZBook 15-inch and 17-inch Mobile Worsktations - Options Missing From BCU Logs After Update to BIOS version 01.33
Release date : 18-Nov-2015
Last updated : 19-Nov-2015
DESCRIPTION
The resulting list after performing the Get Config command from the HP BIOS Configuration Utility (BCU) is missing several items that should be included.
SCOPE
Computers:
  • HP ZBook 15-inch Mobile Workstation
  • HP ZBook 17-inch Mobile Workstation
BIOS Version:
  • Version 01.33
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Download SoftPaq
HP Notebook System BIOS Update
Version: 01.34
Revision: A Pass: 1
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
Hardware platforms affected : HP ZBook 15 Mobile Workstation, HP ZBook 17 Mobile Workstation
Support Communication Cross Reference ID : IA04896599
