HP ScanJet Pro 3500 f1 flatbed scanner - Product specifications
Technical specifications
Automatic document feeder specifications:
Name
Input tray capacity
50 sheets of 75g/m2
Minimum paper size
148 x 51 mm
Maximum paper size
3100 x 216 mm
Minimum paper weight
45 g/m2
Maximum paper weight
120 g/m2
Minimum paper guiding space
51 mm
Supported operating systems
Windows 7
Windows 8
Windows 8.1
Windows 10
OS X El Capitan 10.11
Product dimensions
Product dimensions
Height
Depth
Width
145 mm
387 mm
460 mm
5.58 kg
Power consumption, electrical specifications and acoustic emissions
Power usage drops significantly while in Ready or Sleep mode, which saves natural resources and saves money without affecting the high performance of this product.
AC power
FB scan
Duplex ADF scan
300dpi
600dpi
300dpi
600dpi
AC110V
6.4 W
6.0 W
14.2 W
7.5 W
AC230V
6.8 W
6.3 W
12.4 W
8.4 W
Power
Sleep mode
Off
AC110V
1.28 W
0.055 W
AC230V
1.29 W
0.073 W
Operating environment range
This product is intended to be supplied by a Listed Power Unit, marked with LPS or Limited Power Source. The power supply is rated 100–240V~, and has a DC output of 32 Vdc, 1.56 A, 50 W.
Name
Temperature
Operating the scanner: 10° to 35° C
Storage: -40° to 60° C
Relative humidity
Operating the scanner: 15% to 80% non-condensing 10° to 35° C
Storage: up to 90% at 30° to 60° C
