HP ScanJet Pro 2500 - Product Views
This section describes the physical components of the HP ScanJet Pro 2500.
Front view
  • 1. Paper guides
  • 2. Document input tray
  • 3. Document output tray
  • 4. Scan button
  • 5. Simplex/duplex toggle button and LED indicator
  • 6. Scan shortcut toggle button and LED indicators
  • 7. Cancel button
  • 8. Error LED indicator
  • 9. Power button
Back view
Figure : Scanner rear components
  • 1. USB port
  • 2. Power connector
Serial and product numbers
The serial and product numbers are located on the bottom of the scanner.
Control panel
Use the buttons on the control panel to power the unit on and off, and to start or cancel a scan.
Callout
Name
1
Power button
Press the Power button to power on the scanner. Press and hold the Power button for three seconds to power off the scanner.
2
Error LED Indicator
Indicates an error with the scan.
Callout
Name
1
Cancel Button
Press the cancel button to cancel a scan.
2
Scan Shortcut Toggle Button
Press this button to toggle through and select a scan shortcut option:
  • Scan to PDF
  • Scan to JPEG (picture)
  • Scan to Email
  • Scan to Cloud
The selected shortcut will be indicated by the corresponding LED indicator.
The settings of the shortcuts can be configured in the HP Scan software.
3
Scan to PDF LED Indicator
Indicates that the Scan to PDF shortcut is selected.
4
Scan to JPEG LED Indicator
Indicates that the Scan to JPEG (picture) shortcut is selected
5
Scan to Email LED Indicator
Indicates that the Scan to Email shortcut is selected
6
Scan to Cloud LED Indicator
Indicates that the Scan to Cloud shortcut is selected
7
Simplex/Duplex Toggle Button and Indicator
Press this button to toggle between simplex and duplex scanning. When the LED indicator is on, it indicates duplex scanning function.
8
Scan Button
Press the Scan button to initiate a scan.
