HP ScanJet Pro 4500 fn1 Network Scanner - Sleep Mode and Auto-Off Settings
Sleep Mode and auto-off settings
By default, the scanner will enter Sleep Mode after 15 minutes of inactivity, and will turn off automatically after two hours of inactivity to conserve power.
Windows: To change the default auto-off settings, use the Touch Panel or Embedded Web Server.
OS X: To change the default auto-off setting use the Energy Pane.
  1. Start HP Utility.
  2. Click the Energy icon.
  3. Select a Lamp Mode setting.
  4. Select an auto-off time setting from the Automatically power off the scanner: drop down box.
