    Fix HP Printer issue on macOS
Sprout by HP - How to Use the Wacom Pen Tablet With Your Sprout
This information applies to the Sprout by HP
The Wacom pen tablet works as a cursor or as a stylus in apps that support it. For the touch-enabled versions of the Wacom pen tablet, you can also touch the tablet to control the cursor like a trackpad or use two finger gestures such as pinch and zoom.
Use the following steps to map the Sprout screen to the pen tablet.
  1. Connect the pen tablet to your Sprout and install the drivers and software following the directions that came with the device.
  2. To map Sprout's display to the pen tablet, open Control Panel and search for Wacom Tablet Properties. Click the result to open the properties.
    Figure : Opening the pen tablet properties
  3. In the tablet properties, click the Mapping tab.
  4. Make your selections to map the display to the pen tablet. There are many settings from which to select, including mapping individual monitors or a portion of a screen to the pen tablet. You can configure these settings to suit your needs. The following list shows two examples.
    • To control both screens and map Sprout's entire screen (the vertical screen and the touch mat), select Full in both the Screen Area and Tablet Area selection boxes. This is the default setting.
      Figure : Mapping the Sprout extended display to the pen tablet
    • To map one of the displays to the pen tablet, for example the touch mat, select Monitor 2 in the Screen Area selection box.
      After defining a portion of the display, you might need to use a mouse to access the entire display area. In this example, you might need to use your mouse to access the vertical screen.
      Figure : Mapping the Sprout touch mat to the pen tablet
