HP LaserJet Pro M402, M403, MFP M426, MFP M427 - Removal and replacement: Multipurpose tray (Tray 1) roller
This document provides the procedures to remove and replace the Multipurpose (MP) tray (Tray 1) roller.
Before performing service
Turn the printer power off
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
MP tray (Tray 1) roller part number
RL2-0656-000CN
Roller, MP tray (Tray 1)
Required tools
  • No special tools are required to remove this part.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
Make sure that the printer initializes to a Ready state.
Print a page from Tray 1 to make sure that the printer is functioning correctly.
Step 1: Remove the roller
The M427/M426 printer is shown in this procedure. However. the instructions are valid for the M403/M402 printers.
  1. Press the door-release button, and then open the toner-cartridge door.
    Figure : Open the toner-cartridge door
  2. Release two tabs between the roller collar and roller, and then rotate the top of the roller out and away from the printer.
    Pushing down on the top of the roller might make it easier to release the tabs.
    Figure : Release two tabs
  3. Remove the roller.
    Figure : Remove the roller
Step 2: Unpack the replacement assembly
Unpack the replacement part from the packaging.
Do not touch the gray spongy portion of the replacement roller. Skin oils on the roller can cause paper handling problems.
Recycle and unpack
Figure : Recycle and unpack
Step 3: Install the roller
  1. Position the replacement pickup roller with the pins in the provided slots on the holder, and then rotate the top of the roller up and toward the printer.
    Figure : Install the roller
  2. Continue to rotate the top of the roller toward the printer (callout 1), until two tabs (callout 2) snap into place.
    Figure : Engage two tabs
  3. Close the toner-cartridge door.
    Figure : Close the toner-cartridge door
