    Fix HP Printer issue on macOS
HP LaserJet Pro M402, M403 - Clear paper jams in the output bin
Use the following procedure to check for paper in all possible jam locations in the output bin.
  1. If paper is visible in the output bin, grasp the leading edge and remove it.
    Figure : Remove the jammed paper
  2. Open the rear door.
    Figure : Open the rear door
  3. Remove any jammed paper from the rear door area.
  4. Close the rear door.
    Figure : Close the rear door
