Remove and Replace the Hard Disk Drive for Pavilion 15-ab000 Notebook PCs
This document applies to HP Pavilion 15-ab000 notebook computers.
Before you begin
  • Have available a pair of tweezers or needle-nose pliers and a Phillips-head screwdriver.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Before starting, power off the computer and wait for components to cool before starting these procedures.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion 15-ab000 notebook computers.
Removing the hard disk drive
To remove the hard disk drive, first follow the instructions to remove the battery, the optical drive, the rear corner covers, and the base enclosure, then follow the steps to remove the hard disk drive.
  warning:
Step 1
Find the battery lock latch identified by the lock icon on the bottom of the computer and slide it to the unlock position.
Sliding the battery lock latch
Step 2
Find the battery release latch identified by the battery icon and slide the battery release latch to the release position to partially eject the battery.
Sliding the battery release latch to release the battery
Step 3
Lift the front edge of the battery and remove the battery from the battery bay.
Lifting and removing the battery
Step 4
Now remove the optical drive.
Remove the 6.5 mm P1 Phillips-head screw that secures the optical drive to the base enclosure.
Screw that secures the optical drive
Step 5
Grasp the optical drive bezel and carefully slide the optical drive out of the base enclosure.
Removing the optical drive
Step 6
Remove the rear corner covers.
Remove the two 12 mm P1 Phillips-head screws that secure the corner covers to the base enclosure.
The screw locations that secure the corner covers
Step 7
Carefully lift the corner covers to disengage the tabs that secure them to the base enclosure and remove.
Removing the left cover
Removing the right cover
Step 8
Now, remove the base enclosure.
With a pair or tweezers, remove the two Mylar screw covers from the base enclosure.
Mylar covers to remove
Step 9
Remove the thirteen 6.5 mm P1 Phillips-head screws that secure the base enclosure to the top cover.
Screw locations of the thirteen screws to remove
Step 10
Remove the two 5 mm P1 Phillips-head screws that secure the base enclosure to the top cover.
Two screw locations
Step 11
To prevent damage to the base enclosure, take extreme care when separating the area around the optical drive bay from the top cover.
Carefully separate the edges of the base enclosure from the top cover...
Separating the edges of the base enclosure from the top cover
... and slide it off the display panel hinges.
Lifting  the base enclosure off the display panel hinges
Step 12
To remove the hard disk drive assembly, first find the hard disk drive adapter connector.
Location of the hard drive and the hard disk adapter cable
Step 13
Use care to prevent damaging the ZIF connector and ribbon cables.
Using minimal force, lift the locking bar up on the hard disk drive adapter ZIF connector...
Lifting the locking bar on the hard disk drive connector
...and disconnect the hard disk drive adapter ribbon cable from the system board.
Disconnecting the hard drive ribbon cable from its connector
Step 14
Lift the right edge of the hard disk drive assembly...
Lifting the edge of the hard drive
...and slide the tabs on the left side of the hard disk drive assembly out of the notches in the top cover.
Removing the hard drive assembly
Step 15
Place the hard drive assembly in a static dissipative bag.
Placing the hard drive assembly in a static dissipative bag
Replacing the hard drive assembly
Use the steps in this section to replace the hard drive assembly and other removed components.
Step 1
Insert the tabs on the hard disk drive assembly into the notches in the top cover...
Inserting the tabs of the hard disk drive into the notches on the top cover
...and lower the hard disk drive assembly into position.
Lowering the hard drive into position
Step 2
Insert the hard disk drive adapter ribbon cable into the hard disk drive adapter ZIF connector on the system board...
Inserting the hard disk drive adapter cable into its connecter on the system board
... and press the locking bar down to lock the cable into place.
Pressing the locking bar down to lock the cable into place
Step 3
To replace the other parts removed for this operation, slide the base enclosure onto the display panel hinges.
Ensure that the wireless antenna and display panel cables are free from being pinched between the base enclosure and top cover.
Sliding the base enclosure onto the hinges
Step 4
Place the base enclosure into position on the top cover. Apply pressure to the edges of the base enclosure to snap it into place.
Applying pressure to snap the base enclosure into place
Step 5
Replace the two 5 mm P1 Phillips-head screws that secure the base enclosure to the top cover.
Two screw locations
Step 6
Replace the thirteen 6.5 mm P1 Phillips-head screws that secure the base enclosure to the top cover.
Thirteen screw locations
Step 7
Place the two Mylar screw covers into position on the base enclosure.
Mylar screw cover locations
Step 8
Align the corner covers with the base enclosure and press down on the corner covers to secure them into position.
Replacing the right corner cover
Replacing the left corner cover
Step 9
Replace the two 12 mm P1 Phillips-head screws that secure the corner covers to the base enclosure.
Screw locations to secure the corner covers
Step 10
Insert the optical drive into the optical drive bay...
Inserting the optical drive
...until the optical drive bezel is flush with the side of the base enclosure.
Optical drive is flush with the side of the computer
Step 11
Replace the 6.5 mm P1 Phillips-head screw that secures the optical drive to the base enclosure.
Step 12
Insert the rear edge of the battery into the battery bay and lower the battery until it is properly seated and the battery release latch clicks.
Replacing the battery into its bay
Step 13
Slide the battery lock to the lock position to secure the battery.
Sliding the battery latch lock into the lock position
