HP 27vc IPS LED Backlit Monitor - Product Specifications
The HP 27vc is a 68.6 cm (27 inch) IPS LED Backlit monitor.
Figure : HP 27vc IPS LED Backlit Monitor
27vc monitor front view
P1B75AA
Technical specifications
LED feature
Specification
Display size
68.6 cm (27 inch) diagonal
Display type
IPS with LED Backlight
Aspect ratio
16:9
Brightness
250 nits
Inputs
1 VGA
1 HDMI
1 DVI-D
HDCP support on digital inputs
Scanning frequency
Horizontal: 24 to 94 KHz
Vertical: 50 to 76 Hz
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 9,000,000:1
Response time
7 ms gray to gray (with overdrive)
Power consumption
35 Watts max power consumption (32 Watts typical power consumption)
Operating temperature
5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Storage temperature
-20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Tilt
-5 to +25 degrees
Dimensions
W x D x H (unpacked):
62.2 x 19.2 x 45.4 cm (25.0 x 7.6 x 17.9 inches)
Unpacked: 5.3 Kg (11.7 lbs)
Country: Flag Thailand
