    Looking for Site Help?
HP EliteDisplay E242 24-inch Monitor - Specifications
Panel
Specification
Model
M1P02AA - HP EliteDisplay E242 24-inch Monitor
N0Q25AA - HP EliteDisplay E242 24-inch Monitor head only
Type
24-inch IPS/PLS with LED backlight
60.96 cm (24-inch) widescreen
Panel active area (W x H)
51.84 x 32.4 cm (20.41 x 12.76 in)
Resolution
1920 x 1200 at 60 Hz
Aspect ratio
16:10
Viewing angle (typical)
Up to 178° horizontal/178° vertical
Brightness
250 cd/m
Contrast ratio (typical)
1000:1 Static; 5,000,000:1 Dynamic (DCR)
Response time (typical)
7 ms gray to gray
Pixel pitch
0.27 x 0.27 mm
Pixels per inch (PPI)
93.9
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
72%
User controls
Specification
Buttons or switches
Dynamically adjust depending upon OSD screen selected
Languages
Chinese (simplified), Chinese (traditional), English, French, German, Italian, Japanese, Netherlands, Portuguese, and Spanish
On-screen display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information
Signal interface/performance
Specification
Horizontal frequency
30-80 kHz
Vertical frequency
50-60 Hz
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1600 x 1200 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
Maximum pixel clock speed
170 MHz
Anti-glare
Yes
Video/other inputs
Specification
Plug and play
Yes
Input connectors
1) DisplayPort 1.2
(1) HDMI
(1) VGA
HDCP support on DisplayPort and HDMI
USB
(3) USB 2.0 (Two downstream and one upstream)
Cables included
(1) DisplayPort 1.8 m (5.9 ft)
(1) VGA 1.8 m (5.9 ft)
(1) USB 1.8 m (5.9 ft)
Audio
N/A
Speakers
N/A
Power
Specification
Power supply
Internal
Input power
100-240 V at 50/60 Hz
Maximum power
38 W
Typical power
30 W
Sleep power
0.5 W
Power cable length
1.9 m (6.2 ft)
head only model - 1.83 m (6 ft)
Mechanical
Specification
Dimensions (W x D x H)
Unpacked with stand: 56.22 x 18.9 x 51.9 cm (22.13 x 7.44 x 20.43 in)
Unpacked without stand (head only): 56.22 x 5 x 37.74 cm (22.13 x 1.97 x 14.86 in)
Packaged: 65.5 x 22.6 x 44.7 cm (25.79 x 8.9 x 17.6 in)
Unpacked head only: 4.2 kg (9.26 lb)
Unpacked with stand: 6.23 kg (13.73 lb)
Packaged head only: 6.4 kg (14.11 lb)
Packaged with stand: 8.43 kg (18.58 lb)
Detachable stand
No
Height adjustable
Yes, 150 mm
Tilt range
-5° to +25° (+0/-3)
Swivel
±45°
Pivot
90°
Environmental
Specification
Temperature
Operating: 5° to 35° C (41° to 95° F)
Non-operating: –20° to 60° C (-4° to 140° F)
Humidity
Operating: 20% to 80% non-condensing
Non-operating: 5% to 95%, 38.7° C max wet-bulb
Altitude
Operating: 0 to 5,000 m (0 to 16,400 ft)
Non-operating: 0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free display glass
Yes
Low halogen
Yes
Mercury-free display backlighting
Yes, mercury-free LED backlighting
What is in the box?
Specification
Monitor and accessories
HP EliteDisplay E242 24-inch Monitor (and column stand) or HP EliteDisplay E242 24-inch Monitor Head Only
AC power cord - 1.9 m (6.2 ft)
VGA Cable - 1.8 m (5.9 ft)
DP Cable - 1.8 m (5.9 ft)
USB 2.0 cable - 1.8 m
Documentation
CD (includes user guide, warranty, drivers)
HP Display Assistant
Miscellaneous
Specification
User guide languages
Arabic, Chinese (simplified), Chinese (traditional), Czech, Danish, Dutch, English, Finnish, French, German, Greek, Hungarian, Italian, Japanese, Kazakh, Korean, Norwegian, Polish, Portuguese (Brazil), Russian, Slovenian, Spanish, Swedish, and Turkish
Warranty languages
Color
Black
Security lock-ready
Yes
Country of origin
China
Country: Flag Thailand
