    Fix HP Printer issue on macOS
Sprout by HP - Opening Adobe Illustrator on the Touchmat
This information applies to the Sprout by HP
This document describes how to use Adobe Illustrator on the touchmat of your Sprout.
Use the following instructions:
  1. Go to Control Panel and select Programs.
    Figure : Programs
    Programs selected in Control Panel
  2. In the Programs menu, click Sprout Settings.
    Figure : Sprout Settings
    Sprout Settings selected in Programs menu
  3. In the Sprout Settings, check the box to Permit non-Sprout applications on the touch mat.
    Figure : Non-Sprout applications
    Non-Sprout applications with check box circled
  4. Open Adobe Illustrator and drag it down onto the touchmat.
    Figure : Dragging Adobe Illustrator to the touchmat
  5. On the touchmat, change the Workspace format to Touch. The program will work with other workspace settings as well, however HP recommends using Touch.
    Figure : Changing Workspace format to Touch
    Changing the Workspace format to Touch
