HP LaserJet Enterprise M806, MFP M830 - Load Tray 2 and Tray 3
The procedure to load paper for Tray 3 is the same as for Tray 2. Only Tray 2 is shown here.
  1. Open the tray.
    Do not open this tray while it is in use.
    Figure : Open the tray
  2. Adjust the paper-length and paper-width guides by squeezing the adjustment latches and sliding the guides to the size of the paper being used.
    Figure : Adjust the guides
  3. Load paper into the tray. Check the paper to verify the guides lightly touch the stack, but do not bend it.
    To prevent jams, do not overfill the tray. Be sure that the top of the stack is below the tray full indicator.
    If the tray is not adjusted correctly, an error message might appear during printing or the paper might jam.
    Figure : Load paper
  4. Close the tray.
    Figure : Close the tray
  5. The control panel shows the tray’s paper type and size. If the configuration is not correct, follow the instructions on the control panel to change the type or size.
  6. For custom-size paper, you need to specify the X and Y dimensions for the paper when the prompt displays on the product control panel.
    Figure : X and Y dimensions
Tray 2 and Tray 3 paper orientation
Paper type
Image orientation
Duplex mode
Paper size
How to load paper
Preprinted or letterhead
Portrait
1-sided printing
Letter, Letter Rotated, Legal, Executive, Oficio (8.5 x 13), 11 x 17,A3, A4, A4 Rotated, A5, SRA4, B4 (JIS), B5 (JIS), Oficio (216 x 340), 8K 270 x 390mm, 16K 195 x 270 mm, 8K 260 x 368 mm, 16K 184 x 260 mm, 8K 273 x 394 mm, 16K 197 x 273 mm, custom sizes
Face-down
Top edge at the back of the tray
Automatic 2-sided printing
Letter, Letter Rotated, Legal, Executive, Oficio (8.5 x 13), 11 x 17, 12 x 18, A3, A4, A4 Rotated, RA 3, SRA4, B4 (JIS), B5 (JIS), Oficio (216 x 340), 8K 270 x 390mm, 16K 195 x 270 mm, 8K 260 x 368 mm, 16K 184 x 260 mm, 8K 273 x 394 mm, 16K 197 x 273 mm, custom sizes
Face-up
Landscape
1-sided printing
Face-down
Bottom edge toward the right side of the tray
Face-up
Prepunched
Portrait
1-sided printing
Holes toward the right side of the tray
Automatic 2–sided printing
Holes toward the left side of the tray
