The HP Pavilion 23xw is a 58.4 cm (23 in) IPS LED Backlit monitor.
Figure : HP Pavilion 23xw IPS LED Backlit Monitor
LED feature
Specification
Display size
58.4 cm (23 in) diagonal
Panel active area (width x height):
53.1 cm x 32.3 cm (20.9 in x 12.7 in)
Display type
IPS with LED Backlight
Aspect ratio
16:9
Brightness
250 cd/m²
Inputs
1 VGA
2 HDMI (with HDCP support)
Scanning frequency
Horizontal: up to 80 KHz
Vertical: up to 76 Hz
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
7 ms (typical) gray to gray
Pixel pitch
0.265 mm
Pixels per inch
96
Power consumption
27 Watts max power consumption (25 Watts typical power consumption)
Operating temperature
5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Storage temperature
-20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Relative Humidity
20 to 70%
Dimensions
H x W x D (unpacked):
40.4 x 53.1 x 15.0 cm (15.9 x 20.9 x 5.9 in)
Unpacked: 4.0 kg (8.8 lb)
