HP 3D Capture Stage Product Specifications
The 3D Capture Stage is an accessory for the Sprout by HP PC that assists you in capturing 3D images.
Figure : 3D Capture Stage
3D Capture Stage
Technical specifications
Feature
Specification
Dimensions
Length: 20 cm (7.87 in)
Height: 4 cm (1.57 in)
1 kg (2.2 lb)
Turntable
Motorized, with 360 degree rotation and 15 degree tilt
Restraints
4 rubber magnetized restraints
Scan diameter limit
19 cm (7.48 in)
Weight limit
2 kg (4.5 lb)
Connectivity
USB 3.0
