HP mt245 Mobile Thin Client - Specifications
Product specifications
Feature
AMD SoC (chipset is integrated with processor)
Graphics
Integrated AMD Radeon R4
HD content required to view HD images
Internal
14 in diagonal HD1 WLED anti-glare flat SVA, eDP (1366 x 768)
VGA
Port supports resolutions up to 1920 x 1200 external resolution at 60 Hz
HDMI
v1.4 supporting: up to 1920 x 1080 at 60Hz (HDMI cable sold separately)
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Storage and drives
16 GB M.2 SSD
For hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less
Memory
Standard
  • Two SODIMM slots (only one slot is populated)
  • DDR3L-1600MHz Single Channel Support (with transfer rates up to 1600MT/s)
Memory is non customer accessible / upgradeable
Maximum
  • Up to 4 GB
Memory speed is dependent on processor. Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed.
Networking/communications
Wireless
  • 802.11b/g/n (1x1) WiFi and Bluetooth 4.0 Combo
Wireless access point and Internet service required and sold separately. Availability of public wireless access points limited. 802.11 WiFi and Bluetooth combo sold separately or as an optional feature.
Communications
  • Realtek Ethernet (10/100) NIC
  • Supports Wake on LAN
Audio/mutlimedia
Audio
  • DTS Studio Sound
  • Dual speakers
  • Single digital microphone
  • VGA Webcam
    *Internet access required
Keyboards/pointing devices/buttons and function keys
Keyboard
  • Full-sized textured black island-style keyboard
Pointing devices
  • Touchpad with multi-touch gestures enabled
  • Taps enabled as default
  • Multi-touch gestures enabled
Software and security
Preinstalled software
  • HP Device Manager
  • HP True Graphics
  • HP Velocity
  • HP Easy Shell
Security
  • Security Lock slot (Lock sold separately)
Power
Power supply
  • HP 45W Smart AC adapter (external)
Primary battery
  • 4-cell, 41 WHr Li-ion
  • HP Fast Charge technology (charge from 0% to 90% takes less than 90 min)
Battery life
  • Up to 7 hours
Power conservation
  • Standby
  • ACPI compliance
Environmental
Energy Star certified and EPEAT Silver registered
EPEAT registered where applicable. EPEAT registration varies by country.
Weights and dimensions
Starting at 1.79 kg (3.95)
Weight will vary by configuration
Dimensions (W x D x H)
34.54 x 24.15 x 2.39 cm (13.60 x 9.51 x 0.94 in)
Height varies depending upon where on the notebook the measurement is made
Ports/slots
USB 3.0 - 1
USB 2.0 - 1
VGA - 1
HDMI - 1
Headphone (Line out-stereo)/microphone (input - mono) - 1
AC power - 1
RJ-45 - 1
Digital media slots
M.2 (internal, for WLAN) - 1
Mutli-format digital media card reader (supports SD/SDHC/SDXC) - 1
