    Windows 11 Upgrade Guide
HP Color LaserJet Enterprise M552, M553 - Printer specifications
The following specifications are correct at the time of publication, but they are subject to change.
Technical specifications
Printer model names and product numbers
Model name
M552dn
B5L23A
M553n
B5L24A
M553dn
B5L25A
M553x
B5L26A
Paper handling specifications
Paper handling features
M552dn
M553n
M553dn
M553x
Tray 1 (100-sheet capacity)
Tray 2 (550-sheet capacity)
Tray 3 (1 x 550-sheet paper feeder)
The M552 model accepts one 1 x 550-sheet paper feeder.
The M553 models accept up to three 1 x 550-sheet paper feeders.
Optional
Optional
Optional
Printer stand
Optional
Optional
Optional
Optional
Automatic duplex printing
Not available
Connectivity specifications
Connectivity features
M552dn
M553n
M553dn
M553x
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Hi-Speed USB 2.0
Easy-access USB port for printing without a computer and upgrading the firmware
Hardware Integration Pocket for connecting accessory and third-party devices
Not supported
HP Internal USB Ports
Optional
Optional
Optional
Optional
HP Jetdirect 3100w BLE/NFC/Wireless Accessory for printing from mobile devices
Optional
Optional
Optional
Optional
HP Jetdirect 3000w NFC/Wireless Accessory for printing from mobile devices
Optional
Optional
Optional
Not supported
HP Jetdirect 2900nw Print Server accessory for wireless connectivity
Optional
Optional
Optional
Optional
Integrated HP near-field communication (NFC) and Wi-Fi Direct functionality for printing from mobile devices
Not supported
Not supported
Not supported
Print specifications
Print features
M552dn
M553n
M553dn
M553x
Prints 33 pages per minute (ppm) on A4 and 35 ppm on letter-size paper
Not available
Not available
Not available
Prints 37 pages per minute (ppm) on A4 and 40 ppm on letter-size paper
Not available
Easy-access USB printing (no computer required)
Not supported
Mass storage
Mass storage features
M552dn
M553n
M553dn
M553x
HP Secure High-Performance Hard Disk
Not supported
Optional
Optional
Optional
Other specifications
Other features
M552dn
M553n
M553dn
M553x
1 GB base memory
For the M553 models, the base memory is expandable to 2 GB by adding a DIMM memory module.
The M552 model does not support memory expansion.
Security: HP Trusted Platform Module for encrypting all data that passes through the printer
Optional
Optional
Optional
Optional
4-line graphical display with 10-key keypad
Not supported
Color touchscreen control panel
Not supported
Not supported
Not supported
Supported operating systems
The following information applies to the printer-specific Windows PCL 6 and macOS print drivers and to the in-box software installation CD.
Windows:: The HP Software Installer installs the “HP PCL.6” version 3 print driver, the “HP PCL 6” version 3 print driver, or the “HP PCL-6” version 4 print driver, depending on the Windows operating system, along with optional software when using the software installer. Download the "HP PCL.6" version 3 print driver, the "HP PCL 6" version 3 print driver, and the "HP PCL-6" version 4 print driver from the printer-support website for this printer: www.hp.com/support/colorljM552, www.hp.com/support/colorljM553.
macOS: Mac computers are supported with this printer. Download HP Easy Start either from 123.hp.com/LaserJet or from the Printer Support page, and then use HP Easy Start to install the HP print driver. HP Easy Start is not included in the HP Software Installer.
  1. Follow the steps provided to download the printer software.
Supported operating systems and print drivers
Driver installed
Windows 7, 32-bit and 64-bit
The "HP PCL 6" printer-specific print driver is installed for this operating system as part of the full software installation.
Windows 8, 32-bit and 64-bit
Windows 8.1, 32-bit and 64-bit
Windows 10, 32-bit and 64-bit
The "HP PCL-6" V4 printer-specific print driver is installed for this operating system as part of the software installation.
Windows Server 2012, 64-bit
The software installer does not support Windows Server 2012 but the "HP PCL 6" version 3 and "HP PCL-6" version 4 printer-specific print drivers do support it.
Windows Server 2012 R2, 64 bit
The software installer does not support Windows Server 2012 but the "HP PCL 6" and "HP PCL-6" version 4 printer-specific print drivers do support it.
Windows Server 2016, 64-bit
The PCL 6 printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
macOS 10.13 High Sierra, macOS 10.14 Mojave, macOS 10.15 Catalina
The HP print driver is available for download from 123.hp.com/LaserJet.
Supported operating systems can change.
For details on client and server operating systems, and for HP UPD driver support for this printer, go to www.hp.com/go/upd. Under Additional information, click the links.
Minimum system requirements
Windows
macOS
  • Internet connection
  • Dedicated USB 1.1 or 2.0 connection or a network connection
  • 2 GB of available hard-disk space
  • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
  • 1.5 GB of available hard-disk space
The Windows software installer installs the HP Smart Device Agent Base service. The file size is approximately 100 kb. Its only function is to check for printers connected via USB hourly. No data is collected. If a USB printer is found, it then tries to locate a JetAdvantage Management Connector (JAMc) instance on the network. If a JAMc is found, the HP Smart Device Agent Base is securely upgraded to a full Smart Device Agent from JAMc, which will then allow printed pages to be accounted for in a Managed Print Services (MPS) account. The driver-only web packs downloaded from hp.com for the printer and installed through the Add Printer wizard do not install this service.
To uninstall the service, open the Control Panel, select Programs or Programs and Features, and then select Add/Remove Programs or Uninstall a Program to remove the service. The file name is HPSmartDeviceAgentBase.
Mobile printing solutions
The printer supports the following software for mobile printing:
  • HP ePrint via email (Requires HP Web Services to be enabled and the printer to be registered with HP Connected)
  • HP Smart app
  • Google Cloud Print
  • AirPrint
  • Android printing
Printer dimensions
Figure : Printer dimensions (n and dn models)
Measurement
Printer fully closed
Printer fully opened
1 - Height
399 mm
399 mm
2 - Depth
479 mm
771 mm
3 - Width
458 mm
826 mm
n model: 27 kg
dn model: 27.5 kg
n model: 27 kg
dn model: 27.5 kg
Figure : Printer dimensions (x model)
Measurement
1 - Height
581 mm
581 mm
2 - Depth
479 mm
771 mm
3 - Width
458 mm
853 mm
33.4 kg
33.4 kg
Figure : Dimensions for the 1 x 550-sheet paper feeder
Dimensions of the 1 x 550-sheet paper feeder
Measurement
Accessory fully closed
Accessory fully opened
1 - Height
130 mm
130 mm
2 - Depth
458 mm
771 mm
3 - Width
458 mm
853 mm
5.8 kg
5.8 kg
Figure : Dimensions for the printer stand
Dimensions of the printer stand
Measurement
1 - Height
295 mm
295 mm
2 - Depth
465 mm
900 mm
3 - Width
460 mm
460 mm
17.7 kg
17.7 kg
Figure : Dimensions for the printer with one 1 x550-sheet tray and stand
Dimensions of the printer with the 1 x 550-sheet paper tray and stand
Measurement
Printer and accessories fully closed
Printer and accessories fully opened
1 - Height
876 mm
876 mm
2 - Depth
479 mm
900 mm
3 - Width
458 mm
853 mm
51.1 kg
51.1 kg
Power consumption, electrical specifications, and acoustic emissions
Power consumption
Review the power consumption for each printer status or function.
Power consumption (average, in watts)1
Printing
Ready
Sleep
Auto-off
Off
624 W
33.6 W
3.95 W
1 W
0.1 W
1Power reported is highest value measured for all printer models using standard voltages.
Electrical specifications
Review the electrical specifications, including power requirements and rated current.
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. This will damage the printer and void the printer warranty.
Recommended volts and amps
Specification
110-volt models
220-volt models
Power requirements (volts)
110 to 127 volts (± 10%)
50/60 Hz (± 2 Hz)
220 to 240 volts (± 10%)
50/60 Hz (± 3 Hz)
Rated current (amps)
12 amps
6 amps
Acoustic emissions
Review the acoustic emissions, including sound power level and sound pressure level.
Ensure the printer is installed in an area where the printer sound level will not disturb workers.
Sound power level
Acoustics: Sound power level (pages per minute (ppm))1
Declared per ISO 9296
Printing (33 ppm)
LwAD = 6.5 Bels (A)
Printing (38 ppm)
LwAD = 6.5 Bels (A)
Ready
LwAD = 4.7 Bels (A)
1Acoustic values are subject to change.
Sound pressure level
Acoustics: Sound pressure level (pages per minute (ppm))1
Printing (33 ppm)
LpAm = 51 dB(A)
Printing (38 ppm)
LpAm = 51 dB(A)
Ready
LpAm = 32 dB(A)
Operating-environment range
In order to operate properly, the printer must be in an environment that meets certain specifications.
Operating-environment specifications
Environment
Recommended
Allowed
Temperature
17° to 25°C
15° to 30°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
