HP Scanjet Enterprise Flow 5000 s3 - The LCD is having display issues or scanner buttons are not working as expected
The following symptoms indicate a problem with the scanner front panel.
  • LCD issues: The display is blank, or part of the display content is missing.
  • Button issues: Buttons are unresponsive, or the wrong action occurs when you press a button (for example, you get a single-sided scan when you press the Scan Duplex () button.
  • LED issues: LEDs are not working, or are staying in the wrong state.
If the scanner exhibits any of these problems, contact HP support at www.hp.com/support.
