HP DeskJet 3630, 4729 Printers - Wireless Printer Setup (Windows)
This document is for HP DeskJet 3630, 3631, 3632, 3633, 3634, 3635, 3636, 3637, 3638, 3639, DeskJet Ink Advantage 3635, 3636, 3638, and DeskJet Ink Advantage Ultra 4729 All-in-One printers.
This document explains how to install the print drivers and other software for your printer to use it on a wireless network. If you have more than one computer on the network, install the software on each computer that you plan to share with the printer.
If you are looking for Mac wireless printer setup information, go to Wireless Printer Setup (Mac).
Step 1: Prepare for installation
Before installing the printer software and connecting to your wireless network, check the requirements, turn on the computer and the router, and set up the printer.
  1. To use your printer on a wireless network, you need the following items:
    • A computer connected to your wireless network
    • Internet access: HP recommends broadband Internet access such as cable or DSL for software downloads, using Web Services, and getting printer updates.
  2. Make sure the router and computer are turned on, and that the computer is connected to the same wireless network to which you want to connect the printer.
  3. Set up the printer, load paper into the input tray, and install the ink cartridges. For more information about setting up the printer, go to First Time Printer Setup.
  4. Turn on the printer and place it close to the computer and within range of the router during the setup procedure.
Step 2: Install the printer software
On the computer you want to print from, start the software installation, and then download and install the HP full feature print driver. It contains the wireless print drivers, as well as HP Printer Assistant software for scanning and other printer management functions.
  1. Disconnect any USB cables from the printer.
  2. Use one of the following options to download the install software:
  3. Double-click the driver file with HP Easy Start in the name in the browser downloads bar or in the Downloads folder to start the installation.
  4. Select your printer from the list of available printers.
    If your printer does not display, click My Printer Is Not Shown.
  5. Select Wireless network (if applicable), click Continue, and then follow the on-screen prompts to set up your printer on a wireless network.
    If the download fails, go to HP Customer Support - Software and Driver Downloads, enter your printer model, if prompted, and then confirm the operating system version is correct. Under Driver-Product Installation Software, click Download next to the full feature driver, and then follow the on-screen instructions to use the guided HP Download and Install Assistant.
Review these frequently asked questions about setting up the wireless network connection.
