HP 2.0 S5000 Speaker System - Setting up the HP 2.0 S5000 Speaker System
This document pertains to the HP 2.0 S5000 Speaker System.
Use the HP 2.0 S5000 Speaker System to add stereo sound to your workspace with USB-powered speakers.
Figure : HP 2.0 S5000 Speaker System
Components on the back of the right speaker
The back of the right speaker contains the speaker connection ports and an on/off and volume dial.
Figure : Components on the back of the right speaker
Setting up the speakers
Use the following steps to set up your speakers:
  1. Connect the audio cable on the back of the left speaker to the audio port on the back of the right speaker.
  2. Connect the audio cable on the back of the right speaker to the audio port on your computer.
  3. Connect the USB cable on the back of the right speaker to the USB port on your computer.
  4. Turn on the speakers by rotating the speaker dial on the back of the right speaker until the dial is in the on position.
    Figure : Rotating the on/off dial
  5. After the speakers are connected and turned on, you can adjust the volume using the Windows Speakers feature in your computer taskbar.
    Figure : Location of the Windows Speakers feature
