HP PCs - Cannot Change the Power Settings in Windows Computers
If IPM+ is installed in your computer, the computer’s power setting option is disabled. The power option settings in IPM+ override the power option setting on the computer.
To set power saving mode, please change the power option settings from IPM+.
IPM+ is a pre-installed application to manage power setting in some HP Commercial desktop and notebook computers. If IPM+ is not installed on your computer and you wish to install it, click here to download IPM+ (SP70081) from the HP Website.
Changing the IPM+ settings
Please follow the steps below to change the IPM+ settings.
  1. Open the IPM+ Console
  2. Under Productivity and Tools, click IPM+, and then click IPMPlusConsoleSE.
    The IPM+ console opens.
    Figure : IPMPlusConsoleSE
    Image: IPMPlusConsoleSE
  3. Select Settings, and then click Power scheme.
    Figure : IPM+ Console
    Image: IPM Console
  4. From the Select power scheme drop-down menu, select Power saving off, and then click Apply.
    Figure : Power scheme settings
    Image: Power scheme settings
  5. To change the power saving options, select other options from power scheme down menu.
Setting power savings option through Windows
If you prefer to set power savings option from Windows OS, uninstall the IPS+.
  1. Open the Uninstall or change a program.
  2. Click IPM+, and then click Uninstall from the listed option.
    Figure : Uninstall
    Image: Uninstall
  3. Follow the on-screen instructions to complete uninstallation.
