HP OfficeJet Pro X series - HP Embedded Web Server (EWS) firmware differences
Depending on which firmware version your HP OfficeJet Pro X series printer is running, there are two different HP Embedded Web Server (EWS) user interfaces:
  • Old interface: Printers using firmware 1409BR or older use the old EWS interface and do not have access to the new printer features that are included in firmware versions 1432DR or newer.
  • New interface: Printers using firmware 1432DR or newer use the new EWS interface, and the following are new printer features:
    • Inactivity Timer Setting
    • Access Control
    • Protect Stored Data
    • Restrict Color
This document explains the differences between the 1409BR and older firmware with the 1432DR and newer firmware for the EWS.
Home tab
The Home tab allows you to customize the page to display specific printer features. The following table shows a side-by-side comparison between the two EWS firmware version Home tab.
Old interface
New interface
The 1432DR and newer firmware is modified so that the EWS features chosen to display on the Home page have a tile layout, which can be arranged on the page by dragging-and-dropping the features, as shown in the below figure, to customize the page configuration.
Figure : Drag-and-drop features
You can choose to display the following printer features on the EWS Home page and choose to display only one or all available features by clicking Personalize, and then check or uncheck the check boxes.
Home tab display features
Feature
Scan to Email*
Scan documents and send them as email attachments
Scan to Network Folder*
Scan documents and save them in a network folder
HP Digital Fax*
Save received faxes directly to your computer, or send received faxes directly to an email
Energy Save Settings*
Minimize the amount of power the printer uses when it is idle and reduce wear on electronic components
Web Services*
Print on the go using HP ePrint and add print apps to your printer using HP Connected
Printer Update*
Check for printer updates
Estimated Ink Levels*
View the status of the ink cartridges and estimated ink levels
Network Summary*
View a summary of the printer's network settings
Print Quality Toolbox
Access the maintenance tools available for the printer
Wireless Setup Wizard
Connect the printer to a wireless network
HP Wireless Direct
View and edit HP Wireless Direct settings
AirPrintTM
View and edit AirPrintTM settings
Job Monitor
View the jobs the printer is handling
Printer Information
View general information about the printer
Administrator
Set up and manage advanced security and usage controls for the printer
Backup
Back up printer settings and configuration
Fax Log
View the printer's fax log
Firewall
Set up and manage the printer's firewall
Printer Reports
View the reports available for the printer
Usage Report
View detailed information about printer usage
Webscan
Scan documents from the web browser
*Default Home tab display feature.
Scan tab
The Scan tab has been slightly modified from firmware version 1409BR and older to version 1432DR and newer. The following information and tables describe the differences between the EWS firmware versions.
Scan to Computer
The Webscan feature no longer has the option to preview the scan in the EWS.
Old interface
Webscan feature with the scan preview.
New interface
Webscan feature without the scan preview.
Scan to Email
The Outgoing Email Profiles is no longer listed as an option in the left navigation pane under Scan to Email, but can be configured in Scan to Email Setup.
The LDAP Settings is no longer listed as an option in the left navigation pane under Scan to Email, but the LDAP setup can be accessed through the Email Address Book.
The Scan to Email Setup no longer displays an Overview area to set up the following options:
  • Outgoing Email Profiles
  • Email Address Book
  • Email Options
The Scan to Email Setup feature now allows you to configure the Outgoing Email Settings and Outgoing Email Profiles without using a setup wizard.
Old interface
The old Scan to Email Setup layout requires you to configure the scan settings on multiple pages.
New interface
The new Scan to Email Setup layout allows you to configure the majority of the scan settings on a single page.
The Scan to Network Folder feature remains unchanged.
Fax tab
The Fax tab remains unchanged.
Web Services tab
For firmware version 1432DR and newer, the Web Services tab no longer has ePrint and Apps listed as menu options in the left navigation pane. Instead, ePrint and Apps are available from the Summary page, as shown in the table below.
Old interface
The ePrint and Apps menu options are listed in the left navigation pane.
New interface
The ePrint and Apps menu options are no longer listed in the left navigation pane and now display on the Summary page.
Network tab
In firmware version 1409BR and older, Internet Printing Protocol was a menu option under the Advanced Settings heading in the left navigation pane. For firmware version 1432DR and newer, Internet Printing Protocol is now its own heading, and you will need to select the Status menu option to configure the Internet Printing Protocol, as shown in the table below.
Old interface
New interface
The 1432DR and newer firmware versions have a *NEW* option to create a User Access List from the Internet Printing Protocol menu.
Figure : User Access List page
Tools tab
The Tools tab remains unchanged with the exception of the addition of a *NEW* report, Color Usage Job Log. The Color Usage Job Log allows you to monitor color ink usage and which users are printing in color.
Figure : Color Usage Job Log report page
Settings tab
There are several additions to the Settings tab with firmware version 1432DR and newer, which include the following:
  • Access Control
  • Restrict Color
Anonymous Usage Information Storage and HP Cartridge Protection are available under Preferences in the left navigation pane; however, they now lower down in the menu list, as shown in the following table.
Old interface
The Anonymous Usage Information Storage and HP Cartridge Protection options are listed at the top of the Preferences menu list and are highlighted in green.
New interface
Anonymous Usage Information Storage and HP Cartridge Protection are available from the Preferences menu list and are highlighted in the blue box.
The Inactivity Timer Setting is a *NEW* feature that allows you to specify that after a certain amount of time of inactivity, the printer logs out the current user and returns the control-panel display to the Home screen. Access the Inactivity Timer Setting feature from the Preferences menu in the left navigation pane, as shown in the below figure.
Figure : Inactivity Timer Setting page
Access Control is a *NEW* feature that provides controls to manage which print features users can access:
  • Enable and Configure Sign-In Methods
  • Sign-In and Permissions
  • Printer User Accounts
Access the Access Control feature from the Security menu in the left navigation pane, as shown in the below figure.
For more information on Access Control, see Access Control.
Figure : Access Control page
Protect Stored Data is a *NEW* feature that allows you to enable job storage on the printer after installing a USB storage device in the rear USB port on the printer.
Access the Protect Stored Data feature from the Security menu in the left navigation pane, as shown in the below figure.
For more information on Protect Stored Data, see Store print jobs on the printer to print later or print privately.
Figure : Protect Stored Data page
Restrict Color is a *NEW* feature that provides the option to restrict the printer’s color usage when printing. All color printing can be disabled or customized for certain users or software applications. The Restrict Color feature for the printer provides the following options:
  • Manage color print job use during printing
  • Disable all color printing
  • Restrict color copying
  • Set custom color printing permissions for users or computer applications
Access the Restrict Color feature from the Copy/Print Settings menu in the left navigation pane, as shown in the below figure.
For more information on Restrict Color, see Restrict color printing.
Figure : Restrict Color page
